Cooling - Help - lsx fox swaps
Old Nov 5, 2012 | 04:06 PM
jvert's Avatar
Default Cooling - Help - lsx fox swaps
What radiator and fan do all the lsx fox swaps run?
Can I use my 5.0L radiator and fan? Or do I have to run the fbody radiator and fan? Any insight would be great thanks.
Old Nov 5, 2012 | 05:11 PM
79LS1FOX's Avatar
Default what radiator & fan
Thats what I'm running in mine, just have to get 1 hose reducer and the coupler that Jags that run sells for the steam hose.
Old Nov 5, 2012 | 08:51 PM
jvert's Avatar
Could you post pics of your engine bay? How did you wire it? Did you splice into the harness?
Old Nov 6, 2012 | 07:23 AM
1bad03snake's Avatar
I'm running fbody parts in mine.
Old Nov 6, 2012 | 09:18 AM
jvert's Avatar
Could you send me or post a pic of your engine bay?
Thanks
Old Nov 6, 2012 | 10:31 AM
EZZZE's Avatar
f body stuff in mine too
Old Nov 6, 2012 | 10:43 AM
RATBOX's Avatar
Camaro radiator and fans here, fit easily. Lower hose is stock F body and the upper is from an 01 Neon. Never gets over 185 in 100* weather and traffic.
Old Nov 6, 2012 | 12:01 PM
willys_truck's Avatar
I am using stock mustang radiator with the flex-a-lite electric fan.
Old Nov 6, 2012 | 06:07 PM
79LS1FOX's Avatar
Default fox radiator&fan
I completely rewired my car with a Ron Francis kit as it had no wiring in it what so ever when I got the car. I had my LS2 harness reworked by Speartech and he provided the hookup for the fan so all I had to do was put a connector on the fan harness for his wire, it is controlled by the computer.
Old Nov 6, 2012 | 06:21 PM
99MUSTANG5.3L's Avatar
I'm running a Jeg's universal aluminum rad with a stock Mustang v6 fan wired to operate on high speed. Never goes above 195*
Old Nov 7, 2012 | 02:26 PM
jvert's Avatar
Looks like im going to run a ford racing 93 fox radiator with a 2001 fbody fan.
Old Nov 7, 2012 | 02:37 PM
Speedstang302's Avatar
is there any reason the stock camaro upper hose wouldnt work?
