Help with Red/Blue wiring harness
When I trace the wires back to the connector it attaches to Blue connector pin 14 and 15. According to LT1swap.com these are for drive by wire.
My motor is drive by cable, which is why i got the red/blue harness and computer. Do i just pull these pins, and then modify it for cable driven??
Any help is greatly appreciated!!!
You just remove the data wiring from the blue connector and add in the tps and iac wiring. If you want the connectors with the color coded wiring with the pcm terminals on them pm me. I can send you the assembled pieces that you will need.
https://lt1swap.com/dbw.htm and https://lt1swap.com/cable_conversion.htm may have the answers but I'm struggling to digest.
in short - I have the same early DBW 6+2 MAF & pedal that the OP had. I would like to keep DBW if I can. OEM harness is gone, so plan is to buy aftermarket harness. 2002 LQ9, DBW, red/blue 411 PCM, manual trans.
Is there a dumbed down summary of the difference between the early DBW and DBC harness? In other words, if I buy a DBC ebay style harness what I need to add or modify to convert it to early DBW setup? It seems like it's only a couple of wires different but I'm not finding the idiots guide to doing so. Struggling to find it laid out clear for my amateur brain.
Do not want to mess with using green/blue on my red/blue harness, I compared those pinouts and it's different enough I don't want that headache. Seems adding DBW provision to a DBC red/blue should be fairly straightforward since it's just tying in the separate module
You will need the matching TAC module for your pedal and for wiring you will remove the tps and iac and add the TAC connector which includes wires to throttle body, data wires to pcm and power/ground. The other wires in that connector are cruise control if you want that.
the red/blue dbw stuff isnt as easy or cheap to find. I ended up switching to p59 pcm just so if I have a component fail I can get a new one quick and cheap
