what should I take for my conversion?
Motor
Tranny
Harness for engine and tranny
Computer
Also it is a drive by wire should I take the pedal
Fuel pump
I would like to spend as little as possible on the swap so if there is somthing im missing or some words of wisdom please post up. Thanks
This will be going in a chevelle will the truck harness work how much modding will the harness need and if I decide to have someone do it what guys do you recommend?
-Yes grab the pedal.
-Harness modifications will depend on you. If switching to a car manifold/TB, then the harness requires some re-work, and of course going into such an old car you can eliminate a lot of stuff.
Remember, everything unplugs and done correctly nothing will need to be cut.
Grab the driveshaft too, that way you KNOW you have the proper yoke.
@gofast. Thank you for the reply these are the things that im talking about somthing that I would completely forget about and not even think of grabing.
You won't need the fuel pump for your swap.
Get the fuse block in the hood and pull as much wiring as possible.
It's what I do.
Here are the issues I ran across.
Needed items: complete engine, trans, wiring harness, ECU and TCU (if applicable), DBW pedal. I had Current Performance do my wiring, so he modified the harness and added the necessary DBW segment through the firewall. He also added a check engine light lead to go to my original dash light.
People will tell you to grab the O2 sensors, but in my humble opinion, the problems old sensors can cause (excess fuel trim changes) can be frustrating. Spring $100 for a new pair from Rockauto or such.
The Maf also falls into this category. The risk of using an unknown MAF is not worth the $70 it costs to go with a new one. Good data saves a lot of heartache.
Absolutely grab the exhaust flanges off of the manifold extensions with the O2 bungs already welded, especially if you are using the stock manifolds. Truck manifold flanges are hard to come by. Speedway sells them for $20 each, but the junkyard will throw away the good ones, and will likely give them to you. Even the short section with the original bungs will save you the risk of having an exhaust leak near your sensors. This causes a great deal of trouble.
Finally, the transmission yoke. I used a 6l90 and found the yoke nearly impossible to find by itself. I finally had to buy a driveshaft from justchevys on ebay, and have them mail me just the yoke to save shipping.
I think 4l80 and t56 transmission yokes are easier to find, but the junkyard will pitch the original if you don't want it.
Good luck.
I am wondering do I need the fuse block and all that is under the hood or do I just take the 7mm screws out from behind it and just take the wires.
