70 Chevelle LS1 T56 build
Old 03-12-2013, 05:25 AM
  #81
alaninin's Avatar
Originally Posted by krwyellowZ28
I asked the same question a while back and got some good replies. I also found an older thread and posted the link with more good info. Basically you use the factory AC compressor signal and tie it into the VA system.
https://ls1tech.com/forums/conversio...ge-air-ac.html
Thanks, I will tap off the wire that comes off the relay and goes to the compressor.
Quick Reply: 70 Chevelle LS1 T56 build
