Purge solenoid and charcoal canister hook up
Does anybody know for sure how the purge solenoid works? Until recently I was under the impression that the fuel tank pressure sensor needed to be hooked up, but now I'm not sure. Will the purge solenoid work by it's self? And if so, how do you hook it to the charcoal canister? The canister i have has 3 ports on it, one says 'fuel tank', pretty straight forward, the line it was hooked to goes to the tank, the other two say 'PCV' and 'carb'. The one labled 'carb' I'm thinking would be the one that would go to the purge solenoid. The 'PCV' one, was originally T'd into the PCV hose that went to the carb and valve cover mounted PCV valve. Should I T it into the line going from the fitting right behind the throttle body to the right valve cover? It seems to me it would just make a big vacuum leak. Or I was thinking I could drill a hole in either the air cleaner box or the air intake going to the throttle body, but not sure since it would be after the MAF if that would be a good idea. Anybody have any thoughts?
The factory evap system works as such. The purge sol/valve was hooked up to a port on the left side of the throttle body behind the throttle blades which provided a constant vacumn to the valve. As hot fuel returned to the tank the pressure in this closed system would rise, causing the fuel tank pressure sensor to tell the pcm to activate the purge valve. Vacumn then pulled these vapors into the engine to be reburned. A vent valve on the other end of the system would also allow fresh air in during this process. The idea was to maintain a neutral condition/ 0psi per say. All vapors were routed to a carbon canister to separate any liquid fuel from being drawn into the engine. Furthermore the system does its own monitoring via the form of EVAP. During these tests The purge valve is opened and the vent valve is closed thus pulling a vacumn of approx. 15 inches. The pcm monitors this vac. for a predetermined period of time to see if it can maintain this reading through the fuel tank sensor. Once it passes the test, normal function can resume. If it fails, check engine light is illuminated and no further tests are run. Normal purge and vent valve operation still remain functional. In conclusion, without a fuel tank pressure sensor there is no way for the pcm to know when to purge the system of excess vapors.
Flame I agree for the most part except in the event of a stuck purge valve the pcm uses this information to open the vent valve to prevent the tank from collapsing.
It primarily relies on quite a few different sensors for operation along with run time. As flame says It will probably function ok without the fuel tank sensor. You just wont have the extra safety measure in event of stuck open purge valve You would need to have a vented gas cap to allow air in also.
I think I'll just give it a shot. Pretty sure I have a vented gas cap just by design of them never sealing very well! No way I could put the pressure sensor in it and have it work because of that cap anyway, not to mention I don't have a vent valve or a place to put one.
Do a google of GM evap controls and go for the tech pdfs.
Just reread your post, you're using a charcoal canster for a carb. It has an inlet for fumes from the carb bowl. That would be the carb port, cap it. Guessing the air inlet on yours is on the bottom.
The pcv line did T into the pcv line or attached to the valve. It is line to hook up to the purge solenoid.
