Why is an "X" pipe/crossover pipe so important?
Old Feb 6, 2013 | 12:34 PM
914turboford's Avatar
Default Why is an "X" pipe/crossover pipe so important?
For my 75 Mercedes 4 door LR4 swap I am running two individual side pipes. The exhaust is already done. I could connect them with a crossover pipe under the bell housing. Why would I want to do that? What is the theory behind X pipes?
Old Feb 6, 2013 | 12:50 PM
toughy v8's Avatar
Helps with exhaust scavenging can be quieter equalizes pressure on each bank sounds like a proper v8 and not 2 misfiring 4 potters
Old Feb 6, 2013 | 01:15 PM
bczee's Avatar
as Toughy said.. you can find many articals by googling it on the web with a lot of good information.
IMO, If possible, use an X or H pipe in your system. But if Performance is not critical for you and to use one is more of a problem or cost is an issue, you can get away with out one just fine.
BC
Old Feb 7, 2013 | 06:11 AM
2nd Gen Fl 'bird's Avatar
Go to Drgas.com and read on their theory.
Old Feb 7, 2013 | 09:33 AM
Pop N Wood's Avatar
Because they make you go faster while making less noise.
Old Feb 7, 2013 | 11:05 AM
Andy1's Avatar
The crossover pipe will greatly reduce that pulsing V8 exhaust note. If you're looking to quiet down the exhaust a bit, it will help. Judging by your system layout, I doubt you'll gain any performance.
Andy1
Old Feb 8, 2013 | 11:50 AM
ls1nova71's Avatar
Not to hijack, but is an 'X' better than a 'H', because the 'H' seems easier to make, and my car has a drone at certain speeds that is really annoying.
Old Feb 8, 2013 | 06:31 PM
kj598bbc's Avatar
@ 914turboford, I hope you like LOUUDD and dont have any noise ordinances around your neighborhood.
