Fuel pump for G-Body
Old Feb 8, 2013 | 09:01 PM
86MonteSSLS-1's Avatar
Talking Fuel pump for G-Body
Hi everyone, Been a while since I've been on. I currently have a Walboro 225 with a vette filter/regulator. Pump performs well, but it noisy as hell. What are you other G-Body cars running ?
Old Feb 9, 2013 | 02:15 AM
85GPLEf41's Avatar
Damn really?? I'm thinking of going with the Racetronix sending unit with the Walbro pump. How noisy is it? BTW what are you running ie: stock sender, lines, and how did you connect to the vette regulator? I'm trying to figure my set up
Old Feb 9, 2013 | 05:16 PM
Mine is loud, it wasn't that bad when I put in 9 yr ago. I mounted filter to frame rail rh side just in front of tank. Used the existing fuel line, then just ran a short hose back to tank from filter. I think tank is for a GN and so is sending unit. Will have to pull it to check rubber mount/bushing might be bad.
Come to think of it I most likely need to change filter, can't remember last time lol. I don't drive it very much, sits in garage most of the time. Gonna start working on it again this year. Life got in the way for a while.
Old Feb 9, 2013 | 06:06 PM
LS1MCSS's Avatar
My walbro is real quite. It must be the years on yours, or is it an external pump?
Old Feb 9, 2013 | 06:10 PM
Internal, and like I said filter most likey needs replaced. And always had problem with sock in tank clogging pretty fast.
Old Feb 10, 2013 | 12:33 AM
85GPLEf41's Avatar
9 years? sounds like you got your $$ worth... I will order mine soon then! your tank full of rust??
Old Feb 10, 2013 | 12:45 AM
the_merv's Avatar
Mine is quiet too..come to think of it the only time I hear the Pump is when it's priming..
Old Feb 10, 2013 | 10:05 AM
No rust I keep fuel treatment in it, crappy fuel thou, really don't care for ethenol at all. Has screwed my motor cycle twice also. truck doesn't seem to care lol
