Microsquirt LSx Walkthrough
I am currently working on a fox-chassis 5.3/76mm/th400/8.8/microsquirt setup and have build 90% of my harness and took step by step pictures as WHAT I BELIEVE TO BE CORRECT. I hope Denmah will review this and see any inconsistencies.
Start by just reviewing what all is needed for the Microsquirt:
Required:
Microsquirt
MS harness
Map sensor + pigtail
Coolant Temp + pigtail
Intake air temp + pigtail
Injectors + pigtails x 8
Throttle position sensor + pigtail
Coils + pigtail x2 (bank harness for lsx)
Optional:
02 sensor (recommended)
I ordered all of my supplies from EFI source..
I also clipped off the whole injector/coil harness from each side to give me a rough estimate on length to get going.. looked like this..
Next, find your Microsquirt computer.. flip it to the backside and find the 4 small screws. Open it up
On the back you will see pins for each piece of the MS harness. Start by taking a 1k 1/4watt resistor, and attaching the leads as shown...
Now take 2 4.7k 1/4watt resistors and attach to pins shown..
Note, my pin #1 is soldered like complete ***, ill probably go back and fix it but you get the idea...
Adding these jumpers are for the correct signal for crank sensor and adding two additional circuits for a v8 in wasted spark ignition
Put the case back together and look for vr1+, this is a shielded wire, but all that is attached is the red wire. This goes to yellow wire on the crank sensor pigtail. (signal)
The purple wire (which i indicated by looping) will go to sensor ground (later on in walkthrough)
The last wire, green, will have a 12v source connected to it from fuse box
Crank sensor is done!
Next find the wires from Microsquirt harness that says INJ1 and INJ2, since this will be a batch fire ignition system, one side is fired, and then the other side.. hence all signals for one side of the engine will be connected to either the green, or the blue respectively.
Next, find your injector harness including clips. I cut this off the donor harness as it makes it easier to visualize how long they need to be, and it also helps keep colors somewhat coordinated.
Either reuse the factory connectors (this was off a truck, if you plan to use truck injectors), or switch clips to these (newer style ford clips I think ev6 is the name)
Now, go grab a soda, beer, sweet tea, because your probably thirsty.
It helps to have your intake pulled where you can set it on a table or work bench and mock everything up.
I put the injectors in half assed and set injector wiring on it (note, wires havent be loomed or routed to not look like butt.
Repeat for the other side of injector clips. Keep in mind that injectors are solenoids. When power is on (key on), and signal (from pcm) sends ground to injector, it opens. So in this case, my power wires were farthest away from the snap clip, so that's where I routed my power wires, and signal wires to the other.
Now you will have 8 wires per side. 4 will be pink, the others are purple, blue, green and orange(red on earlier harnesses) I believe.
Take one bank's pink wires (all 4) and run a power wire to them from the fuse box. I used a 10-12 ga wire, it's probably overkill but it will work.
Do this for both sides
Remember the INJ1 INJ2 green and blue wires? You need these now. Again, since it's batch fire, one side is for one injector, the other is for you guess it, the other bank.
Now you're all done with Crank angle sensor, and all 8 injectors YAY!!
Lets move onto ignition.. it's not tricky but just make sure you read a few times to get them correct.
One note: depending on year of coil pack plug, all the colors are the same, except later models may have an orange wire in place of red. Doesn't really matter as long as they are positioned correctly. early and late model shown here:
Start off by finding the pink wires on the coil pack harness connectors. This will provide 12v to coils. Run a power wire from fuse box.
Next find the black wires on the coil pack harness connectors. These will be grounded. Also find the two larger ground wires in the microsquirt harness. I joined all four of these wires to one fat ground wire with a hoop to ground to the head.
Note: the orange wire shown here may be red on earlier harnesses.
Find the blue wire on the drivers side harness. Note: I used green only to extend length to other side
Connect it to orange on passenger side (may be red on earlier harness)
Connect these two wires driver blue and passenger orange (or red) to Microsquirt yellow/black
Find the orange (or red) wire on drivers side harness, extend it to passenger side. Connect it to green on passenger.
Connect these, orange (or red) from driver, and green from passenger to yellow/white on microsquirt
Next find green on drivers side harness. Connect it to to purple on passenger side
Take both of these green from driver, and purple on passenger and connect them to white/red from microsquirt harness
next take purple from drivers side, connect it to blue on passenger side.
Connect these to white from microsquirt
Now you're all done with Crank angle sensor, Injectors, and coil wiring.
Next up is the AIT sensor. Very easy as colors match. Orange wire labeled AIT goes to the orange on AIT sensor. The black wire from AIT goes to sensor ground (will wire later)
Now Crank angle sensor, injectors, coils and AIT are done.
The next is Coolant Temp. Is it also color correct. My picture turned out like donkey doo doo, but find the yellow wire labeled Coolant and match it to the yellow cts wire. The black wire will go to sensor ground (wire later).
Now CAS, INJ, Coils, AIT and CTS are done.
Next up is the Throttle Position Sensor TPS
Find the blue wire on TPS plug, connect it to tps signal on microsquirt ( believe blue also)
The tan (could be black) wire from TPS plug goes to sensor ground (wired later)
The grey wire from TPS plug goes to 5v reference, shared with MAP
Find your MAP, connect the middle pin orange and connect it to red/green wire from microsquirt harness. Should be labeled MAP
Black wire will go to sensor ground (wired later)
Now connect the TPS Ref 5v wire to grey on TPS plug and yellow (or the last wire left on map)
Note yellow goes to a light blue wire, but only for extension purposes. It connects to TPS reference
Now you're done with CAS, INJ, Coils, AIT, CTS, TPS, and MAP.
Alternate (which I haven't wired yet is o2 sensor) pink wire on microsquirt goes to 02 signal if you are running narrowband.
You should have a total of these power wires: Injectors, Coils, CAS, 12v to pcm.
Outputs reccomended to be wired are for TACH, bootloader and fuel pump.
After testing the harness for continuity at each pin, or hooking it up and loading up MS, you can move tps and see if it moves and changes.. Good indication that things are wired correctly.
I hope this helps anyone wanting to tackle this. Including stopping for dinner and taking pictures it took only about four hours total. Not bad at all considering a factory harness conversion usually takes me 10 - 12 hours!
-Randall
maybe one day when i build one i will do a video and try not to make it confusing but show you guys how i wire it.
one trick i like to do is pull the 12v power wire for the ecu back a bit to wire it to the crank position sensor, then i cut it, splitting it in two about 1ft out, then i take both wires and put them in a spade into my fuse box, with about 5amps or less, this powers the ecu and then powers the crank position sensor without wasting wire or needing to run any extras. pretty neat, safe to fuse them both on the same wire since they are both very low power usage.
https://ls1tech.com/forums/forced-in...anics-how.html
If picture doesn't work.. use the url....
Microsquirt Schematic
Microsquirt is awesome for drag cars with hydraulic non electronic transmissions.
