Project ls swap c10 *update post 48*
I did most of mine with an 80 grit sanding pad folded in half and did it by hand...I feel stupid now lol , but not using the intake so it's all good.Had originally planned to do what you're doing. Wiring looks nice and tucked too!
I did it the hard way... 80 grit sandpaper by hand for a good 6 or 7 hours for 2 days and I'm not done yet! Just bought a car intake though ahah Your wiring looks really nice and tucked
Almost done with the wiring harness. Just need to add a couple wires then wire up a fuse box with relays and its ready. I still have a couple wires I am not sure where they go. I cannot locate them on any of the wiring diagrams. Also I plan to add a couple adle clamps on the back of each head to hold the wiring harness in place so it cannot move around. Getting much closer, hoping to get the heads back by next weekend then it should go together really quick!
![](http://i220.photobucket.com/albums/dd21/mustangguy71/550CF209-1B65-452C-A88E-A571A6A8C024-1230-000000F613D9BA6F_zpsa1176dcf.jpg)
Did a little work to the intake, finished smoothing the top. I plan to add a couple coats of filler primer, hit it with a quick sanding by hand to help smooth some of the bumps out and throw some black on it.
![](http://i220.photobucket.com/albums/dd21/mustangguy71/1FCFFE65-7BD8-4466-8A18-A7885DECB8E3-1246-000000F0DD77A815_zps158a1a63.jpg)
![](http://i220.photobucket.com/albums/dd21/mustangguy71/BE713861-99BD-4C1D-9E66-3A10AE113706-1246-000000F0DFAB2DE4_zps2a6f86f2.jpg)
Also worked on the heads and got the porting all finished up. Plan to assemble them tomorrow and get them installed! Hoping to fire it up first of next week!
crazy question but where are you going to run your wires into the cab? Was really trying to avoid having to drill another hole in my firewall...but it seems inevitable.
LS1Tech Sponsor
That may be the smoothest vortec intake I have ever seen. Nice Work!!
Jon
PSI
Jon
PSI
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic84531_2.gif)
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Meh Its not as smooth as the pictures portray, but it looks much better then stock! I got tired of sanding on it.. haha Thanks!
#34
Well i finally fired it up tonite!! Diddent get to run it long, open manifolds and 9 pm isnt a good mix with my neighbors. But all in all everything seems fine thus far. Plan to run it more tomorrow after work and maybe try and get it to a muffler shop on saturday and get that fixed up. Getting closer to done!!
#37
Got some more things taken care of tonite. Started it and ran a heat cycle. Need to change my evac a little. Pretty much from here just need to get the tune straightened out, swap my adapter plates so the trans sits in the crossmember correctly, double check all fluids, and finish up a couple wiring items to make the rest of the factory gauges work and its ready to hit the muffler shop. Hoping I can get everything done Sunday so I can take it Monday to the muffler shop and get that taken care of. We will see.. On to the pics.
Here is what I did with my dbw pedal. It's perfectly in the stock location, but since the throw is a little different this is what I ended up with.
![](http://i220.photobucket.com/albums/dd21/mustangguy71/FA143B35-42CB-480E-AEE1-1F4BF82E75BE-184-000000F2C4A3CDCC_zps104b8634.jpg)
![](http://i220.photobucket.com/albums/dd21/mustangguy71/0BC89CA2-A345-44EF-BF5D-E6874AAEAAFC-184-000000F07B428136_zps64696ee8.jpg)
![](http://i220.photobucket.com/albums/dd21/mustangguy71/F3F087DF-ACE9-4C62-835A-B5097EF5B8E2-184-000000F07EF71C6F_zps53efafd3.jpg)
![](http://i220.photobucket.com/albums/dd21/mustangguy71/14759830-AC80-4A47-9E39-F3B3D03BBF23-184-000000F08B865FC6_zpse76f1dd9.jpg)
Here is where I used the factory hole and enlarged it to accept the grommet for the pedal wires.
![](http://i220.photobucket.com/albums/dd21/mustangguy71/02826707-3ABD-4A2A-8847-59BE4855DCC1-184-000000F0839533A0_zps03768b1d.jpg)
And here is the wiring 95% done. Need to order a computer bracket. There are a few things I plan to change in the future to clean them up a little better but this is functional.
![](http://i220.photobucket.com/albums/dd21/mustangguy71/C8B0A0B0-D027-4811-A69E-9D8BF1541998-184-000000F08780E57D_zps296dd1de.jpg)
