th350 ls1 problem.
Old Mar 7, 2013 | 09:18 PM
S10xGN's Avatar
I take it you did not test-fit all the parts first? I learned a long time ago, a few extra minutes test-fitting pieces on the bench is worth it in the long run...
Old Mar 8, 2013 | 06:34 AM
mprete's Avatar
this is all test fitting. i bought a junk th350 just to test it all. Someone is borrowing my engine hoist for a couple more days so i cant bolt it all together to the motor till i get that back. Im going to try to clean up the converter snout today and see if that helps. If it doesnt... what else is there to do? its a brand new gm flywheel and i got a used spacer but i compaired it to a brand new one and they are exactly the same. does anyone have a convertert that they know works that i can get a measurement of the snout from? Im thinking its the converter and not the flywheel or spacer that is the issue...
Old Mar 8, 2013 | 08:52 PM
S10xGN's Avatar
The crank (or spacer) socket is supposed to be 1.705" ID, so your converter snout should be a few thou less than that...
Old Mar 8, 2013 | 10:40 PM
the_merv's Avatar
Veteran: Air Force
4L80E Flexplate & Spacer on the back of my 408..I use a TH350 with a PTC 4800 Stall.
p
Old Mar 9, 2013 | 08:52 AM
mprete's Avatar
On your converter, how long is the snout where its machined? It steps down in size where the spacer goes around. How long is that? I dont think the convereter is machined far enough to allow the spacer to slide on far enough. I sanded that part down and got all the paint off and checked again, didnt help at all. It fits on the motor fine. It just doesnt bolt to the converter right with the spacer in place.
Old Mar 9, 2013 | 08:55 AM
mprete's Avatar
Here i drew a picture haha, as you can tell im not an art major, thats why i work on cars, so cut me some slack haha but this is better then an actual picture. You can see the spacer doesnt allow the flywheel to bolt to the converter. I labeled it with "problem"
Old Mar 9, 2013 | 08:55 PM
S10xGN's Avatar
Take the spacer off and fit it on the snout of the converter, it should easily push all the way in up to the outer edge of the spacer. If it's not going all the way on, try your spacer on a different converter. My bet's on the converter being the problem.
Old Mar 9, 2013 | 09:57 PM
BlackLS1Camaro's Avatar
Mine worked just fine but I used the LS1 fbody flywheel and gm spacer/adapter. I had to sand some of the paint off the pilot on the converter but thats only because I bought a new converter from Jegs. When I researched to do mine I read something about the 5.3 flywheel would bolt right on, but then again it could be dished different causing that 1/4 in difference.
Old Mar 10, 2013 | 09:59 AM
bigchief52780's Avatar
i used the 4l80e flywheel and spacer to my 350 and bm holesot converter. everything bolted in without having to slot the holes on the flywheel. i have used a flat washer to fill the gap in between the flywheel and converter without any problems.
Old Mar 12, 2013 | 10:00 PM
mprete's Avatar
got my answer! thanks. I also have a B&M holeshot converter so that must just be how they are. Im just going to use a nice big washer and put it together! I have an appt to dyno the car as it sits on saturday and you will see a build thread in probably a couple weeks. some a-hole hit my truck in a parking lot saturday night and took off so now i have to fix that and that uses all my fun money. Getting body work done on my truck before its first oil change!! FML thanks again for all the help!
Old Mar 12, 2013 | 10:09 PM
mprete's Avatar
by the way for future reference. the parts I used.
GM 6.0 flat flywheel- GM part#19260102 which is superseded from #12621399 (because they now only sell it separate from the spacer and bolts. no more kit)
GM spacer part #12563532
GM longer flywheel bolts part #12563533
By Brett Foote | 2026-06-04 05:00:17
