LQ4/T56/HX55 Turbo Into 1986 El Camino.. Running Now
#121
Sounds like a bad lifter to me.
Locate which side it is coming from, pull the valve cover, remove rocker arms and push rods, spray some b12 chemtool cleaner into the lifters with the straw, reassemble and check again. Or you could just go all out and replace the lifters.
How many miles on this engine?
#123
I have done a fair amount of talking with the oiling guy that worked on the engine that this turbo came off of originally and he and I have came to an agreement that The lack of restriction is unnecessary in my application..
I have had a .125 inch orifice made for the top of the turbo oil feed and will see what effect that has on my oil pressure..
I have a Melling High Volume pump already purchased to go in the car.. No debris in the pan.. Hoping I can salvage it without too many parts replaced..
#124
so today I went to install my orifice and the damn bearing housing is different threads than my spare turbo I used for mockup.. So I have to have that redone..
Just for giggles I started the engine.. let it idle.. pulled the feed to the turbo and capped it and started and let it idle for a moment.. No change in oil pressure.. I'm at a loss.. Anyone care to chime in..
For the record I am running 15w40 Rotella a Wix Filter and the engine is cold when starting..
Noise sounds about the same as it does in the link.
#125
Sweet elco. Great install too. It might sound stupid but since you do live in colder climates it might just be the oil. 15w-40 is really heavy even for summer months. I used to run 10w-30 in my LT1 during summer months and switch to 5w-30 in the winter. ( I live in PA, it can get pretty cold here too.) Anyways, on cold fall days my lifters where always noisy and I would sometimes even have low oil pressure because of how thick the oil was at those temps, but once it warmed up they would stop. That was only 10w-30 in an lt1. LS motors have much tighter tolerances. You might just want to try flushing the 15w40 for some 5w20 or 5w30.
#126
I have picked up a Gen 4 4.8 engine and a set of LQ4 floating pin pistons.. My intent is to make a budget friendly destroked 5.3L.. L92 heads and square port intake and convert to LS3 camaro accessories to make things a bit more asthetically pleasing under the hood.
I know the destroked engine has become something of a redheaded stepchild build.. but I think it would be fun. I mean the 4.8's made quite a bit of torque with some air.. and adding a larger piston to the top can't hurt.. plus so far I have 0 dollars in those parts.
#127
will L92 heads work on a 4.8?
I thought that all of the rectangular port LS heads require a 4.00" bore which as far as I know isn't achievable with a 4.8, 5.3, or 5.7 block. Well, unless you want extremely low compression or have a crap load of money or skill to sleeve the block.
I think part of the reason that de-stroked engines have become like red headed stepchildren (well aside from the fact that all LS engines share the same stroke except the 4.8 and the 7.0, thus making it stupid cheap to turn a 4.8 into a 5.3) is that there are probably a lot less people running stick shift. Personally I'd love to see a 4" bore 4.8 with a turbo and a stick. It would definitely be a screamer. Have the machinist spend a lot of time balancing the rotating assembly and get a Air to Air intercooler for it. I bet you could push 800+ hp @ 8,000 rpm all day long. GM fans could use a modern 302 anyways.
#128
Supporting rod bolts and other mods of course..
#130
Why .125 inch?
The one I installed is much smaller than that…. something like .065 maybe I need to change/enlarge it...
I also found that the small turbine housing spools very fast… it goes positive @ 50% throttle & 2200 rpm
![Name: boost.jpg_zpssifxwl9p.png
Size: 15.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/642154d1501467508-lq4-t56-hx55-turbo-into-1986-el-camino-running-now-boost.jpg_zpssifxwl9p.png)
![Name: 2aa66754-3348-48f9-818e-4899e3c5abfb_zpsa80ja3a5.jpg
Size: 3.38 MB](https://ls1tech.com/forums/attachments/conversions-swaps/642155d1501467508-lq4-t56-hx55-turbo-into-1986-el-camino-running-now-2aa66754-3348-48f9-818e-4899e3c5abfb_zpsa80ja3a5.jpg)
#131
The noise in the video sounds too loud to be a lifter. My bet is that it is a rod bearing. Use an engine stethoscope and see if you can pinpoint the area where it is loudest.
Andrew
Andrew
#132
I was told that that size orifice should supply an ample amount of oil to the turbo with the change in viscosity 15w40 - 5w30.. I didn't question the guy.. he's been on the lube and cooling team for about 20 years.
#133
Unfortunately that sounds bottom end. Very hollow and disheartening sound. Love the build and really like the way the turbo and piping is done to keep the factory airbox. Gbodies look so weird without the hvac case under the hood.
Any chance you can pm me what you paid for your engine from the guy in iowa?
#134
Are you running an HX55? What size housing. What base engine.
LM7 (approx 288K miles) all stock except Z06 Cam & H2 oil pan.
truck intake + 80 lb injectors
2010 Camaro manifolds (upside down)
2" SCH 10 SS pipe, two 38 mm Tial gates (currently with the lightest spring)
HX55 16 cm
single 4" exhaust all the way to the back with 4" diesel pickup muffler
4L80e with stock converter
MS3 Gold Box.
Considering how poor my tuning is, I am pretty surprised by how fast it spins up the turbo. It goes positive around 2200 rpm & 50% throttle, and is on the 5 psi gate spring before it reaches 3000 rpm.
I put in a pretty small orifice in the feed because it was smoking pretty bad when I first started running it with an full flow 1/4" feed line. I may drill it out to 1/8" and see what happens.
I am going to add a little adapter to the Gold Box so I can log the 4l80e input & output speed sensors, that will give me MPH and converter slip..
Size: 15.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/641935d1501466836-lq4-t56-hx55-turbo-into-1986-el-camino-running-now-boost.jpg_zpssifxwl9p.png)
Size: 3.38 MB](https://ls1tech.com/forums/attachments/conversions-swaps/641936d1501466836-lq4-t56-hx55-turbo-into-1986-el-camino-running-now-2aa66754-3348-48f9-818e-4899e3c5abfb_zpsa80ja3a5.jpg)
#136
If anyone is looking for a turbo flange for the HX55:
http://www.ebay.com/itm/HX55-Turbo-F...VWbtIR&vxp=mtr
I had these lasered out for a personal build and had extra made in case anyone else needed them. Check your bolt hole spacing as it might differ based on what your hx55 came out of.
#137
Well finally got engine out of car and torn apart.. breakaways on rods were all within spec except for rod with spun bearing.. it was 30lbft.
Destruction:
![](http://i1024.photobucket.com/albums/y310/ig109/IMG_20160116_165455194_zps7n8lxg3c.jpg)
![](http://i1024.photobucket.com/albums/y310/ig109/IMG_20160116_161752666_zpszljqtwmk.jpg)
![](http://i1024.photobucket.com/albums/y310/ig109/IMG_20160116_161747298_zpsq12gfq9w.jpg)
![](http://i1024.photobucket.com/albums/y310/ig109/IMG_20160116_165436891_zpszmtdcokx.jpg)
Bearings offset rod enough to make counerweight smack piston
![](http://i1024.photobucket.com/albums/y310/ig109/IMG_20160109_204350655_zpsqvdqrrzd.jpg)
![](http://i1024.photobucket.com/albums/y310/ig109/IMG_20160109_204342569_zpsotnuazbx.jpg)
![](http://i1024.photobucket.com/albums/y310/ig109/IMG_20160109_204243963_zpsk6v7waxe.jpg)
So needless to say it's trashed.. Starting the 5.3 build now.. trying to find a deal on a set of 823 / 0821 heads..
Destruction:
#139
A swap to 5w30 , 5w20, or 0w20 solved almost all problems.
#140
I just read through this whole build and am looking forward to an update! I have been running Rotella T6 Diesel 5w40 in all of my cars including an LS6 and 2011 5.3L and never had a problem.
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
