New 6.0 coupe build
Parts are here.....time to start assembling it all. Heres what we got. Tell me what you think. Starting out with 2007 LY6, has the L92 heads which were milled to get comp bumped up to 10.75-1 Lunati double springs, titanium retainers and 7 degree locks, stock valves. All stock internals otherwise except the cam which was custom spec'd .622 int, .600 exhaust, lobe separation 111, intake centerline 108, 231dur int, 243 exh. powerband roughly between 31-6800. Ls2 timing chain and frt cover with 3 bolt cam gear. It will have 1 7/8 primary tube headers into 3 inch collectors with bullets bolted to collector. Edelbrock vic jr intake, 950 Holley ultra HP carb(hardcore black) Msd 6012 box, Miezere elec water pump.
Trans is a turbo 350 with full manual valve body and custom built 8 inch unit from BTE that will stall around 5500. Rear end is a 8.8 with 4.10 gears and the car should weigh in at or a little less than 3100. What you guys think this thing will do? I know its a guessing game, but hoping it goes 6.50s at the very least.
LS1Tech Sponsor
Hey, im also in ky. That should really be a screamer, hopefully ill be able to check it out at the somernites cruise, dont know if you go or not.
If you ever need anything just give me a yell!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic241851_3.gif)
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
Im sure it will! I get discouraged if it doesnt at first, sometimes ya just gotta work out the bugs.
The cruise is in somerset, which is quite a ways from you. Do you ever go to beech bend?
__________________
1-888-467-4491
1-888-467-4491
Drama with the owner wanting to promote his site every where but as soon as someone as someone as much as post a For sale ad on the facebook page its a crime then he posted a For sale ad on the page and someone asked " If you can do it why can't we" And I as well as him and another member were admins of the page but it was my fault it wasn't delete when HE posted the ad and I didn't delete it right away and someone got under his skin........So rather than handling it like a grown man he banned me I was 6ohStang over there. Wished him luck with the site and continued on
