G-body swap **having issues**
I have heard that Transdapt makes another engine mount adapter plate that will sit the engine back another inch. We have the hedman 1-7/8 swap headers, but I'm worried if I move the engine back will this cause clearance issues with the headers??
Anybody have any ideas as to WTF is going on? This should have been an EASY engine swap from what I've seen and read on the web. Why is it being such a pain in the ***? Am I missing something?
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
The Holley pan is too pricey. The sump on the Holley pan is a helluva lot shorter from front to back that is why you have zero clearance issues. I believe it measure 7.xx" where the cts-v is 10.5" and the fbody pan is 11"..
The Headers went in right after that pic..took 5 min..lol
Also, did you keep the alternator on the bottom drivers side of the engine? Cause the steering box is all up in the way.
Those are factory LS1 Fbody Accessories..no issues with clearance.
Here's the best pic I have..I was doing a Cam Swap..
IMO these "Setback" Mounts are garbage. I used the normal $35 ones you find on Ebay, and have had zero issues.
Literally every forward and back clearance is 1/8"..they are tight in there and must have been built with respect to the plates I used.
I'm doing all of this for a friend. I've been in the LS world for a while now. Have my own car (98 Z28 5 sec 1/8th mile car). I knew this should have been an easy swap, but I guess I went the wrong way with the fbody pan. Easy fix though. I'll order the GM swap pan from summit for $150 and I'll give him his money back for the LS pan. I need one for my car....wheelies claimed mine twice.
