Won't run with MAF plugged in
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
I installed a '00 6.0 in my '84 C10 and actually got it started and even drove it today (around the block)
When I plug in the MAF it immediately dies, assumed it was a bad one and swapped another one in but exact same thing. Any ideas?
Also since I am using the original TH350 how would it know when to shift? Do I need to find some way of hooking up the original kickdow
LS1Tech Sponsor
Kickdown and vacuum modulator should be hooked up to get it to shift.
What MAF are you using? Is it the correct one for the tune?
Jon
PSI
Jon
PSI
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic84531_2.gif)
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Thanks for all the input gents.
Jon
PSI
It is a stock MAF. Actually had it programmed to run a 100mm, so when the truck would not stay on, I swapped it out for a factory MAF but got the same results.
Jon
PSI
Chk for +12v between pink and black wires at MAF harness connector with ignition switch ON. Likely you don't have it so maf does nit produce a signal to pcm, so truck won't run. Also don't plug in maf with engine running. Turn ign off first.
Will check in the morn & be more mindful when I plug it back in. TY
LS1Tech Sponsor
Agree with Novaman. Make sure the pinout is correct.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
On the transmission, you need the vacuum modulator hooked up for it to shift. On a 350 turbo, the kick down doesn't need to be hooked up, but it will make the truck feel like a slug at times, since it won't be able to down shift when needed. You could manually downshift it, but that gets really old really fast.
As soon as the sun comes up, I will check it with my voltmeter, maybe post a pic as well.
I think I may have tossed the hose in the bed of the truck back when I just knew I was getting a 4l80e.
The MAF is indeed in the intake tube with the arrow depicting flow pointing towards the engine.
If I have 12+ at the pink or black, I'll go from there.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
How would I test the black wire? Don't want to fry my ecm while basking in ignorance.
Took a pic of the connector and tube as well. Figured if you guys are helping might as well burn the midnight oil...literally.
![](http://i304.photobucket.com/albums/nn183/Kainepeter/2013-03-07230706_zps024145de.jpg)
Ground you can either ohm or test the harness for a brake.yellow wire iirc is a 0-5v ref for the pcm.one thing tho.i recently helped some one on a swap with the same issue and it turned out to be a bad maf.
LS1Tech Sponsor
You can check the ground by putting one tester probe to power and the other to the black wire, it should show batter voltage.
The two gray wires are IAT.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
LS1Tech Sponsor
Im guessing you have 12v between pink and black? Just trying to clarify that you do not have 12v on the black wire too.
What you checked is checking out, the PCM will uses all the sensors combined to make a determination on how the vehicle is running. My guess is you probably have a conflict between your MAP and your MAF readings. You should double check your MAP sensor and your MAP pinout. Glad to hear you are using a multimeter and not a test light!![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
The MAP Pinout is as follows
A Black or Orange with a black stripe. - Low Reference
B Light Green. - Map Sensor Signal
C Gray - 5 Volt Reference.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic241851_3.gif)
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
