Need help oil pan options
thanks
http://www.ebay.com/itm/221199464304...84.m1555.l2649
Its the pan off of a 5.3 in a Hummer H3. GM sells it as a kit for engine swaps. Comes with dipstick and tube, windage tray, hardware, gaskets, and everything. Mucho improved ground clearance over the truck pans.
going to set short block in monday hopefuly.
as looking at this oil pan if stock doesn't work
http://www.summitracing.com/parts/nal-19212593
https://ls1tech.com/forums/conversio...-oil-pans.html
This link has some detailed "opinions" listed as well.
https://ls1tech.com/forums/conversio...body-swap.html
I'm using a Street&Performance modified f-body pan. Only complaint is capacity is 4.5qts.
https://ls1tech.com/forums/16661747-post29.html
GM Muscle Car pan(referenced in an earlier post) part #19212593. I started with this pan but swapped it later to the S&P pan. It's too deep for most muscle cars, it hung 1.5"-2" below the crossmember. And I had steering issues with it. It will get the engine in your car but is not a good long term option. Know a good welder? Modify your own pan.
After all the time spent pulling, replacing the pan, cleaning the classis of Syn Oil...and the pulling it all back together.... I can say, get a pan the do not hang below the cross member.. it just is not worth it and time spent to replace, clean and fix everything, let alone the tow home.
Just spend the money for a pan..
BC
BC, did you modify the F-body pan yourself? If not, whose did you buy?
Yes, I cut it up and had a friend weld it up. I had the original f-body pan that came with the engine.
I didn't cut out as much as S&P does, but just enough to clear the cross member so I would only loose about half qt.
BC
How much the CTS-V pan would hang below. Doesn't seem like much. But it has cause me spped bump and pot hole issue for many years (glad I switched now)
by only cutting back about an 1" at the front peak and then back to the sides of the pan at that angle, I was able to use an un-modified pick up tube. The pictures has the pan as I mocked it up with the panels and tape to check before I had it welded up.
BC
