V12 LS1 Build
Old May 12, 2013 | 05:25 PM
  #281
V12Baker's Avatar
Originally Posted by cam
You guys have a horse power goal for this thing yet? No need to get all antsy about scr or boost until you decide that
We don't have a HP goal yet. We plan to just get it running and have the lowest amount of boost we can get (0 to 3 lbs). After we hit the dyno tons of times to tune it, we'll go from there.
This is mainly a test to prepare us to graduate to LS7s for both V4s and the 12s
Old May 12, 2013 | 06:11 PM
  #282
jbsjunk's Avatar
And nothing is wasted. The cut off parts make the V-4.
Old May 13, 2013 | 07:16 AM
  #283
JameyXJS's Avatar
Pardon me if this has been asked already, but roughly how much does this engine weigh when fully dressed out? My Jag V12 weighs 750 and it only has a displacement of 5.3 liters (326 cu)
Old May 13, 2013 | 09:45 AM
  #284
x11 nut's Avatar
Originally Posted by V12Baker
No joke!
We've built several LS12s so far. One went into a suburban, and another went into 3/4 scale P-51.
We have a bunch of LS parts still laying around from those previous jobs so we're putting together some 12s for ourselves! The process gets refined each time we do it making it a little easier each time hah
We figured out how to section two stock cranks/cams and create our own firing order, and we cut out about 12 grand in crank/cam creation costs.
Got any pics of the P-51 build ??
Old May 13, 2013 | 10:31 AM
  #285
Blackpanther99's Avatar
Originally Posted by Y2KFirehawk
From the very first post...
Missed that. Mybad.
Old May 13, 2013 | 10:35 AM
  #286
Originally Posted by slimbobaggins
Sorry, had to laugh @ this.
That was pretty funny.
Old May 13, 2013 | 10:40 AM
  #287
LSxChevelle's Avatar
On like page 3..."the last LS12 we built weighed in at 442 pounds."
Old May 13, 2013 | 11:28 AM
  #288
Makes sense that it isn't much more weight...If a block weighs around 75lbs the v12 block probably weighs 100-105 since you are only adding more center area. Same with crank...only adding more 'center area'...
Old May 13, 2013 | 02:20 PM
  #289
Drokkers's Avatar
verdy interesting, i think i will stick around to see how this goes.
Old May 13, 2013 | 04:04 PM
  #290
DT2k13's Avatar
Originally Posted by Brian Macy
I can say this deal is 100% real, I went to Norway to tune the one for the P-51 Mustang. It had a Motec M800 sequential fire COP with stock Cam Sync and a external crank trigger to make it easy.
You can see more pics of the dyno and this engine on my facebook: Brian Macy
I am working on a cheaper solution for EFI with this combo, have come up with something already that will work.
There is probably only one such plane in Norway with an engine built by a guy from Seatle area. Norway is rather small with a pop of 5 million people, so unlikely to be another with exactly that spec and unknown to the people tinkering with suchlike. I am sorry to say it leaks everywhere and is considered scrap. To be replaced with another engine.
Old May 13, 2013 | 04:07 PM
  #291
cam's Avatar
cam
Old May 13, 2013 | 04:58 PM
  #292
Eddie Aop Benjamin's Avatar
this is insane
  #293
whats estimated hp ?
Old May 13, 2013 | 04:59 PM
  #294
will these be forsale ?
Old May 13, 2013 | 06:03 PM
  #295
What kind of leak(s)?
That seems like a very small issue on the first of 2 engines built. Should be easy to fix. GMS works great for sealing an oil pan or timing covers. Although the stock front/rear cover seals can be used. The head gasket would be the hardest but still not too hard. Just custom.
Old May 13, 2013 | 06:33 PM
  #296
V12Baker's Avatar
When the motor left Seattle it was incomplete as per request to save money. We sent it with an instruction list of things that needed to be done to complete the build. If it leaks, he never did those.
If it's scrap tell him to send it back, i'll gladly take it.
It's a fine piece of work.
Old May 13, 2013 | 06:57 PM
  #297
sidewayz28's Avatar
Wow.. been a while since I've been on the forum. Yahoo brought me here
Amazing work, I was surprised to see it was from a local shop!
  #298
sidewayz28's Avatar
dupe..
Old May 13, 2013 | 07:07 PM
  #299
V12Baker's Avatar
Originally Posted by 71ANTICARB
Come on guys read the thread. I do believe he has answered bout every question on this page.
I'm going to edit the first post with pictures, FAQ and a video of it running when we get that far (and have something to work with). Until then i'm sure there will be a lot of repeats
Old May 13, 2013 | 07:26 PM
  #300
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
This build, and even this thread made Yahoo! today. Good job, guys!
http://autos.yahoo.com/blogs/motoram...185150870.html
