V12 LS1 Build
http://autos.yahoo.com/blogs/motoram...185150870.html
I must say, some of those comments are really... silly.
The article says "where it's expected to make more than 500 hp".. I don't think people understand that this motor should put out around 525 hp with completely stock parts. I see a fair amount of comments that say there are inline 4s that produce that much power..
We could make a LS12 that could put out over 2000hp, but that's not really useful. We couldn't put enough car under it to make that desirable. With the blower we added, we're going to try and have the 240 sit around 800-1000hp.
cool project..
the V4 with 45mm Mikuni's in a mini sprint or a shifter cart.
The V12 with a 180 degree crankshaft, a dry sump, LS7 rods and pistons and an all carbon ITB setup and a proper carbon airbox.
Speaking of that, now I need to go back and look at the pics for the oil pan setup.
I wonder if that last half of the Crank welded in at 180* from where it's at now would make a difference...
I'd like to know the firing order and the degree intervals between firing. With a block having a 90 degree bank angle and the crank journals being at 120 intervals, it has to be interesting.
I think the OP should have like a lottery for one of these completed engines, each ticket could be like $5.00. Seeing what the view count is on this thread the OP would make about a million dollars and have to only give out 1 engine......
Powerball ticket < V12 lottery ticket
Great work on the V-12. Maybe all this intyerest will spurn GM to put one of their V-12's into service?
peace
Hog
