V12 LS1 Build
Old May 8, 2013 | 09:44 PM
  #241
stoverz28's Avatar
Originally Posted by V12Baker
It's something we're considering for sure! Figured we'd keep that door open
If you stick with it then I'm sure you won't have any problems making a living building these things. Especially with all the attention you have already gotten in just a few days.
Old May 8, 2013 | 10:50 PM
  #242
Blackpanther99's Avatar
Originally Posted by spudsmcknze
Man all this modern technolgy and I am stuck with an antique
Thats a sick engine
Old May 9, 2013 | 07:05 AM
  #243
1fast bird's Avatar
I'm interested in the v4 engine. There are so many platforms this could be used on...... paired with the right turbo it would be awesome!
Old May 9, 2013 | 01:46 PM
  #244
330 4HL's Avatar
hi
dig the V-4; how much will it weigh all dressed?
With all that power, what are you planning to use for the diff on the Z?
I'm surprised it can handle the Toyota power but the torque from the V12 will surely shred it.
Old May 9, 2013 | 03:50 PM
  #245
WS6_MAC's Avatar
Cool work, and trick welding process.
But using a 78MM TB???
Using a crank that is has 90 degree offsets for a V12, does that mean 2 cyl fire at the same time?
Can the oil pump and oil galaries flow enough oil for the extra crank journals and the 8 lifters?
I can see detonation happening in the last 2 cylinders due to cooling problems as the stock pump can't flow enough l/min.
A V16 seems technically better no?
Old May 9, 2013 | 05:24 PM
  #246
Y2KFirehawk's Avatar
Subscribed for fapping material
Old May 9, 2013 | 07:57 PM
  #247
Are you guys gonna try to get a aftermarket intake for the block?
Old May 9, 2013 | 08:02 PM
  #248
From the very first post...
Found this 1471 littlefield blower laying around so we decided to make a new intake for the next step.
Attachment 400953
Old May 9, 2013 | 08:16 PM
  #249
jonnyv713's Avatar
This is an absolute must have for my Jag XJS! Out with a v12 to a sbc back to a v12! Perfect!
Old May 9, 2013 | 08:36 PM
  #250
AFKAY's Avatar
I can't wait to see this run ... I've had the crazy dream ever since the Fulkner engine that GM would make one... wow
Old May 9, 2013 | 08:57 PM
  #251
Grendel's Avatar
Amazing.
Old May 9, 2013 | 09:19 PM
  #252
A_Pinstriper's Avatar
I didn't see it mentioned anywhere, but what is the compression ratio ?
Also, just curious what injectors you're using in it.
Amazing work, by the way.
-Aaron
Old May 10, 2013 | 07:11 AM
  #253
OTT308's Avatar
Head gaskets? Oil pumps cope ok? Awesome work.
Old May 10, 2013 | 07:57 AM
  #254
71ANTICARB's Avatar
Come on guys read the thread. I do believe he has answered bout every question on this page.
Old May 10, 2013 | 08:00 AM
  #255
2001CamaroGuy's Avatar
Nobody reads anything these days....
Old May 10, 2013 | 09:16 AM
  #256
cam's Avatar
cam
Well done gents! Old school cut and weld em up. Im certainly a fan of that way of thinking, and most of all doing. Cant wait to see it run down the track full jam!
Old May 10, 2013 | 03:04 PM
  #257
V12Baker's Avatar
-Aaron
We are shooting for 8:1
We haven't ordered pistons yet so that number is subject to change.
Haven't gotten far enough for injector choices yet
Old May 10, 2013 | 03:17 PM
  #258
Why 8:1? That seems unnecessarily low when the stock LS1 came with 10:1 (which works perfectly fine). Are you planning to boost it?
Old May 10, 2013 | 03:22 PM
  #259
jbsjunk's Avatar
In post number one he said that he was using a Littelfield 14-71 blower.
Yes to boost.
Old May 10, 2013 | 03:26 PM
  #260
Yes to boost.
Opps, my mistake. I forgot he had put up the picture of the 14-71 (it's been a while since I read through the entire thread).
