HELP!! 5.3 obs silverado starts than dies
truck is a 1990 Silverado with a 2003 Chevy Tahoe 5.3 liter motor. Everything is hooked up via the wiring harness from PSI conversions, fuel lines ran with the new fuel pump upgraded to a Walbro 255. First initialfire up the motor ran for 3-5 seconds, then died no shutter or anything just turned off. Found out the cross over to go on the intake to the passenger side had no openings so fuel was squirting up words of 8 inches of the intake. We put a gauge on the fuel line to check pressure and it had good pressure. with the key on, the fuel pump did not buzz which is kinda weird right?
so we went over it again today and fired up on the first go around, it ran very good for 10 seconds then again cut off. Tried turning it over again and nothing. Anyone have any thoughts kinda stumped at this point.
Thanks, Justin
Thanks, Justin
The connection on the psi harness is different than the stock.harness. the stock harness too s hooked up. The psi harness has a totally different sensor connection. Currently it is not hooked up.
Good Luck.
LS1Tech Sponsor
Jon
PSI
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic84531_2.gif)
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
