Grand national swap for 6LE
Old 05-26-2013, 04:24 PM
Swapper's Avatar
Default Grand national swap for 6LE
Hey everyone, needs some help on a swap im doin. Ive done several swaps before but none into g-bodies. Im having some issues lining up the motor mounts and wanted to see what some people have done.
car is a 1987 Grand National
4.8l
4l60e
these are the mounts im using.
im using the "hotrod" oil pan setup but i just cant seem to get the motor low enough to line up into the mount holes. im using the stock grand national frame mounts. im thinking i have to move the mounts up like an inch or so on each side.
heres some pics:
also what did you guys do for driveshafts? ive got a bit of an issue on that too. i do have a great driveshaft shop a block away but just trying to see if theres some kinda stock driveshaft i can use instead of cuttign this one up first.
heres how far back the trans sits.
just a random pic:
Old 05-26-2013, 04:25 PM
Swapper's Avatar
wow sorry didnt realize how big the pics were
Old 05-26-2013, 04:50 PM
lsonboost's Avatar
I have never done one, but is it possible to spin the frame mounts 180°?
Old 05-26-2013, 04:52 PM
bczee's Avatar
Try flipping or swapping sides...from the look of the mount two bolt side and the plate bolt as they are aligned, if the set up is flipped, it might line up.?
Yeah, the photo are super sized!
Good luck.
BC
Old 05-26-2013, 05:08 PM
Swapper's Avatar
i flipped the mounts on the lock today cause they wouldnt line up before. they lin eup now i just cant go down any further. i was thinkin of unbolting the frame mounts and moving them up or flipping them.
this is how far off when i had the mounts on the correct side. i couldnt go any further back on the motor cause it was already hittign the firewall. with them flipped i got plenty of room but like i said the frame mounts need to either come up or the motor mounts need to go down.
Attached Thumbnails Grand national swap for 6LE-101_3329.jpg   Grand national swap for 6LE-101_3330.jpg
Old 05-26-2013, 05:18 PM
bczee's Avatar
I usually bolt the plates, mounts and frame stands together on the engine and drop it in, then mark the new hole location. Remove engine, drill new holes and you're done!
One trick I use when bolting the frame stand back down. I use some glue to hold the lock washer and nut together and use a bunch of different wrenches, flex sockets and extentsions.
Just looked at the last set of picture, I would not do just the 180. Flip upside down, switches sides.
BC
Old 05-26-2013, 08:10 PM
KY Nova's Avatar
Are the stools the same as a smallblock? Just a thought.
Old 05-26-2013, 09:14 PM
N20zuki's Avatar
You prob need to swap to a Monte Carlo frame mount, Those swap kits are designed for the 8cyl application and even 6cyl base model G-bodies require 8cyl mounts. That looks to be your issue.
Old 05-26-2013, 10:44 PM
Swapper's Avatar
Alright ill have to let my buddy know so he can try and find some. Thanx.
Any info on driveshaft or should I just have this one shortened?
Old 05-26-2013, 10:51 PM
bigmandengo's Avatar
Your swap mounts are designed for pre-73 sbc/bbc frame stands. You have the 3.8 buick frame stands in the GN.
Old 05-27-2013, 09:58 AM
N20zuki's Avatar
Until you get the motor in and securely mounted I wouldn't even think about the driveshaft. But you will prob have to have it shortened or buy a new one. When I did my LSx swap I used dennysdriveshaft.com for mine and ordered a 3.5in steel one from them. I am very pleased with the quality and fit.
Old 05-27-2013, 02:18 PM
Swapper's Avatar
alright thanx everyone. i will see what he wants to do on this whole thing and post pics accordingly.
im used to doin 3rd gen swaps, theyre a little easier. although i have done a couple others which also were alot easier then this one so far. lol
Old 06-09-2013, 10:00 PM
Swapper's Avatar
alright finally had time to mess with it and got it in. ended up just pullin the frame mounts off, mounting them to the block, put the motor back in and marked it, pulle dit out and drilled the new holes and then put the motor back in a bolted up. of course all my friends show up after i finish everything by myself. lol oh and they bbq'd at my house while i was working. lol
Owner brought more parts too. guess he bought these turbo manifolds off a member here.
oh hes not running the truck manifold. i just put it on there.
Old 06-18-2013, 01:42 AM
Swapper's Avatar
Old 06-22-2013, 08:39 PM
Swapper's Avatar
Old 06-22-2013, 10:59 PM
LS1BADZ's Avatar
What's the specs on the rear wheels/tires? Tuck nicely
Old 06-23-2013, 06:15 AM
LS BRAVADA's Avatar
At least it's still turbo/intercooled. Nice
Old 06-23-2013, 03:10 PM
Swapper's Avatar
believe they are just the stock wheels with e/t streets.
Old 07-15-2013, 07:27 PM
Swapper's Avatar
alright so i need some more help. pretty much lengthen/shortened, removed wiring from a factory 01 truck harness. got a computer with vats removed. have things wired up but having some issues. i have never used the stock fuse block before (usually i do the lt1swap.com) fuse block. but i followed there directions for hooking this thing up and its jsut not firing. i can crank it but that it but thats it.
so the stuff in red i have fuses or relays in. i have constant battery to the B+ terminal on the left side.
one circled in blue pops the fuse whenever i put it in.
does anything go on the 2 circled in black?
Old 07-16-2013, 12:22 PM
6LITEREATER's Avatar
Think it is because of the 60#s on stock tune?
Quick Reply: Grand national swap for 6LE
