My track/street 240sx LS Swap
#241
Let's just say I have LOTS invested. I do sell my old stuff to recoupe some cash. The chase bays harness seemed to work on the engine just fine, it just didn't communicate anything over to the chassis as it should if that makes sense. Someone would be much better off with the race chassis sub harness and wire up the chassis side theirselves.
And the brake brackets just sold out over the weekend. The next batch will be in next week though. And the website is finally up, and a Facebook page that has frequent updates.
Facebook.com/ctsvbrakeswap
Ctsvbrakeswap.com
Ctsvbrakeswap.com
Well that's a relief cause I bought the race version mainly cause my car wasn't a choice but I'm sure glad that worked out that way... I looked it over after reading this thread and all colors and pins seem to match up against a factory harness just wish they used factory wiring colors to simplify it but thanks for the heads up.
#242
i just ordered a chase bays harness myself and its a race harness. hopefully it works properly. this was the first time i'd seen any negative reviews.
Mines also going into a camaro not an s13/s14 so hopefully it works.
nice build btw.
nice build btw.
#243
Then you've not been looking very hard; there are quite a lot of reviews about his harnesses being complete crap and when they try to return to get it corrected, they never respond or downright refuse they received it. I hope it works out for you, but usually the case is you only get quality service from him if you're gonna be featured in a magazine.
#244
#245
#246
Not to thread jack but Beejis is right, they have a terrible reputation for their wiring harness on other 240sx related forums.
Cant wait to see the beast after this weekend!!!!!
#249
You must be related to Broadfield, Another extra clean 240
http://zilvia.net/f/showthread.php?t=357297
#252
Hey guys!!! Sorry I haven't updated in a while, I did end up going with wiring specialties and haven't looked back. Works perfectly. The car was painted but I never ended up putting the body on because I was waiting to dyno tune it first.
Well I got it on the dyno and at idle and just putting around it does fine, but as soon as it starts making power it's having crazy crazy blow by issues. Like oil on the windshield bad. It's literally gushing out if the valve cover breathers.
Now I did a compression test and it's 190 across the board, so then I tried a leak down yes and that's a 5% drop across all 8 cylinders. So I'm lost guys, any ideas?
#256
Yup I have the valley cover running to the port behind the throttle body and both valve covers have breathers on them. I'm stumped.... Starting to think the cylinder walls might be glazed over because leak down and compression are good at low rpms but the blow by doesn't happen until it's making power.
#257
I have that problem on mine, rings cut for nitrous, I've added a catch can and still it pushes the dipstick out the hole, I'm taking the heads off and might close the gap on the rings and use less nitrous or add a vacuum pump system
