Help! My 5.3 Loses Power At Operating Temp
I would also put a scanner on and check to make sure all sensor are reading within the operating range. Check for any DTC code and it might lead you to where the problem is.
if it starts up ok.. and runs ok, but once you reach operating temp.. it stalls.. hmmm. .try disconnecting the MAF and see how it runs..
But you're going to have to provide us with more info on what the scanner is reading and anything else.
BC
I'm guessing that you have a sensor problem. Watch the MAF/MAP readings when cold and compare to when it acts up. Make sure the coolant temp reads correctly. See if the O2s are switching.
I've read some have tried to run TPI or LT1 pump.. and had somewhat of the same ...
BC
To me it sounds like bad regulator or it is not connected to vacuum.
Do you have a Vacuum Referenced Regulator ?.. if not, vacuum should not come into play ???
If your seeing constant 58-60 psi. I would be looking at other areas..
I have also recall in the past that those Granatelli MAF can be a problem.
BC
58-60 key on engine off. Less than that idling.
Since this was his first start up it could be something simple. Like Old Geezer said, probably having issues when it tries to go into closed loop mode. So air leaking by the MAF, MAP sensor bad, something not plugged in, it is also pretty common for people get the left and right side 02's corss wired. Need to check the basics and rule out the stupid mistakes before the trouble shooting can get too theoretical.
The second problem was my placement of the Granetelli MAF sensor. It's critical to mount the sensor right after the air cleaner element...not in the stock location which is right before the throttle body. Luckily I'm using a CAI designed for a 2000 Silverado and was lucky enough to package it. In the latest Hot Rod Magazine, there is an article on custom fitting the new Coyote 5.0 Ford motor. MAF placement is super critical in that application and it hit home that a good tune may not be critical when hybrid building an LSx powered vehicle but it's a great idea.
I've only driven the truck around the area near my house. I need to take this thing out for an extended drive which includes some freeway driving before I can honestly say the problem is solved.
