G-Body power steering help
any help would be greatly appreciated!
thanx in advance
What accessories are you running; Y, F or truck style?
Most trucks had hydro boost from the factory and the power steering reservoir has a 3rd port for the hydro boost drain. If running a Vette or F-body PS pump you might want to run a remote reservoir with an extra port for the hydro drain.
Also, if you still have the GN PS pump, make sure to take out the valve that the pressure hose screws into (which also screws onto the back of the reservoir) and all hardware to go with it. You'll need the valve for the new PS pump so that the output pressure is matched to the steering box...many have not and complained about "twitchy" steering from pump pressure output being much higher than our G-bodies came with.
oh another quick question is how did you guys wire up the fuel pump?i cant seem to find the wires from the OEm wiring diagrams!
Either you are incorrect as to the yr of the car, or someone has changed the brakes. That HB unit looks to be an OEM from an 84ish type Regal. It's likely not an aftermkt HB, as they usually have an accumulator can on them.
As mentioned, you can mod the press valve on the LS pump. I used a kit made by Borgeson, to do the pump o my 55.
You can also use a "T" in the return line, to get the fluid back to the pump res.
If the pump has a 2nd return port, and you use a "T", do not hook the line to the upper port. The pump will be noisy.
Hydroboost has 2 returns that ran to the factory reservoir. I just ran a tee connector inline under the pump to connect both return lines. Had a custom hose made for the pressure side. No twitchiness or excess noise
I consider hydroboost an upgrade.
http://hooniverse.com/2012/11/29/tru...amaro-edition/
http://shop.advanceautoparts.com/web...erm=hydroboost.
http://www.google.com/#sclient=psy-a...w=1920&bih=954
PS, gm hydroboost is the same on a 1 ton truck as a car application. Also, reminder that returns are same & you can use a tee, though a dual inlet reservoir is supposedly better. Like I said< I haven't had problems in 10 years of running a tee with mine.
http://www.stu-offroad.com/suspensio...droboost-3.htm
We were just confused putting it back together with the LS because I had thought it was pump to HB, HB to steering, steering to reservoir but there's the t fitting so I thought maybe pump to HB AND steering off the T and then two return lines to the reservoir. I did the conversion a long time ago...
