Wireless coil packs
Old Sep 26, 2013 | 10:06 PM
BLULS1Z28's Avatar
Default Wireless coil packs
I was looking for something and swear I seen them, pretty sure they where made by holly. my question is has anyone seen these or am I just crazy
Old Sep 26, 2013 | 10:29 PM
shanex25's Avatar
You're crazy
Old Sep 26, 2013 | 10:34 PM
BLULS1Z28's Avatar
Not wireless meaning there's no plug wires but there was a little box that the wiring harness plugs into and it wirelessly controlled coils
Old Sep 26, 2013 | 10:45 PM
1981TA's Avatar
No, I doubt it. At a minimum, the coils would still need at least two wires and a ground and some form of RF receiver/controller--which I can't see working very well with a several-thousand-volt spark firing off hundreds of times per second right there. That's a lot of expensive engineering just to avoid using controller wires.
Old Sep 26, 2013 | 11:41 PM
superdave84's Avatar
Something like that would cost a fortune because:
A. It would be so far beyond complicated to design and produce..if it's even possible
B. There is no market for such a thing
If you don't like the look of the coils (let's be honest, who does?) make or modify fuel rail covers, or hide the coils somewhere else and use longer plug wires.
Old Sep 27, 2013 | 12:10 PM
spacemanspif's Avatar
It does exist...sort of
$2,500 at Jegs "MSD atomic EFI LS kit".
Old Sep 27, 2013 | 01:09 PM
bczee's Avatar
I would see a lot of issue with mis-fire and timing due to many sources of electrical static or interference.
Sounds like a good way of winning races. .Just build a jammer or something to cause interference ! LOL.. could even cause a mis-fire and blow up everyones engine.. yikes !
Just thinking ! ...
BC
Old Sep 27, 2013 | 01:22 PM
BOXCHEV's Avatar
I wouldn't want anything on my engines to be 'wireless'.. Most people already deal with the headaches of wire trouble shooting. Could you imagine dealing with some wireless crap.
Though a bare motor with no harness laying over it looks nice, I will just have to deal with it.
NOTE: Not my pic below. Thread to where I found the image: https://ls1tech.com/forums/conversio...on-please.html
Old Sep 27, 2013 | 04:09 PM
cruisin'73's Avatar
"Man your car is running like crap!"
"Ya I know, my wireless coils don't get any bars at the track."
Old Sep 27, 2013 | 04:44 PM
bczee's Avatar
Dawg.. I forgot to plug each coil into a USB port to charge the battery of each coil last night !!
Old Sep 27, 2013 | 04:51 PM
LS1MCSS's Avatar
That's the PCM that is made into the fuel rails. It still has to have wires to the coils.
Old Sep 27, 2013 | 09:44 PM
vazfx16's Avatar
I think I know what he is talking about. He his talking coil on plugs like BMW etc does
Old Sep 28, 2013 | 09:15 AM
fieroguru's Avatar
I don't like seeing wires, so i relocated my coils to the end of the heads and oriented them so the plug wire points up and the harness connector points down, hiding the vast majority of the harness from view. You might not have room to place them on the ends of the heads, but the same could be done in other locations as well.
Old Sep 29, 2013 | 01:36 PM
Streetlegal?'s Avatar
I built a bracket and put mine where the AC was.
Old Sep 29, 2013 | 02:29 PM
1981TA's Avatar
Wires are my friends. The more, the merrier
Just kidding, this is a pic of my preliminary mockup, before I got POed at my Holley EFI and went the carb route. All of that wonderful plumbing and wiring work is now considerably more professional.
Old Sep 29, 2013 | 05:11 PM
Pop N Wood's Avatar
No matter what you do the coil packs will at least need 12 volt power.
Like someone said above the "MSD atomic EFI LS kit" just builds the ECU into the fuel rails reducing the number of wires.
I like the stock coil packs. Keeping the spark plug wires short and isolated from each other is the way to go.
