BRP Bind
Old May 5, 2004 | 09:57 PM
HotRod68Camaro's Avatar
Default BRP Bind
I finally got around to installing the BRP rack & pinion kit and have run into major bind problems. I followed the instructions correctly but it seems that if i mount the rack and pinion further forward and downward it creates less bind. Any suggestions? Should i move it further towards the driver side (probably not)? Will post pics as soon as possible.
Old May 7, 2004 | 06:25 PM
Nine Ball's Avatar
LS1Tech Co-Founder
I know exactly what you mean, I ran into the same issue about a month ago. Then when I put the engine in I ran into anoher issue (power steering lines hitting alternator housing)
I'll be working on the car tomorrow most of the day, if you want to come over and have a look I'll steer you clear on what to avoid. I'm only 20 minutes from Katy.
Old May 7, 2004 | 06:43 PM
Yea sure id love to go over. PM me w/ ur info
Old May 8, 2004 | 03:18 PM
ahowudoin's Avatar
How much did the BRP kit cost? Let us know what you do to fix the problem.
Old May 9, 2004 | 12:17 PM
E-mail BRP for the cost of the kit and they can give you proces seperately or for everything together. I fixed the problem by lowering the whole system and angling it back a lil bit further. Im now working on forming the steel tube to shape and it a PITA. But once thats done the motor is goin in
Old May 9, 2004 | 09:22 PM
Nine Ball's Avatar
LS1Tech Co-Founder
yep, I had to lower mine 1/2" and angle it back a bit to work without binding. But, the damn tubes were hitting the alternator (f-body serpentine setup). So, I had to bend the tubes around myself and also cut a notch in the back plastic cover of the alternator. Fits now, but damn it is tight down there.
Old May 9, 2004 | 09:26 PM
Nineball - https://ls1tech.com/forums/conversions-swaps/151502-brp-nightmare.html In this post you took closeup pics for me of the steering shaft and rack and pinion. I was wondering if you were goin to leave the hole in the tube like it is in the pic or what you plan on doing about it b/c i have run into the exact same prob and will prob have to cut out the same sections. any suggestions?
Old May 9, 2004 | 11:30 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Leaving the holes. I actually had to cut the upper hole a little bigger since then since I dropped the assembly lower. Dang U-joints were contacting the tube. If I were to do another subframe with this setup, I think I'd have just used larger diameter tube.
Still plenty of structural metal in the area, and underside of that K-member, as well as the other cross member a couple inches in front of the K-member. I think it should be just fine.
