Project RIP IT- C-10
Old Oct 19, 2015 | 03:18 PM
  #241
98TA6.0's Avatar
my issue was transmissions. I had a 60E graveyard. never using that trans ever again.
Old Oct 19, 2015 | 07:23 PM
  #242
truckdoug's Avatar
Originally Posted by static low 92
Thanks.
I'd really have rather sold it to be honest and not still be posting about putting motors in this stupid truck. Maybe 10th try is a charm?
at least no one can say you aren't persistent (stubborn as a **** is what my wife calls it)
Old Oct 20, 2015 | 07:15 AM
  #243
static low 92's Avatar
I think it starts to become stupidity on my part at this point lol
Old Oct 20, 2015 | 10:50 AM
  #244
98TA6.0's Avatar
Getting close. No worries though man. Youve got a turbo LS swapped square body. Im glad to have gotten out from under mine but at least it was cool whe i owned it. Your truck is pretty cool.
Old Oct 23, 2015 | 07:52 AM
  #245
Got my crank back yesterday, really happy with the specs.
Now if I just had a good block to stab it into lol
Old Oct 23, 2015 | 11:32 AM
  #246
Well the Aluminum block is getting way to far out of hand.
Been line bored= needs shorter timing chain
Been decked .0020 and will need shims
Will be bored and require a 3.80 piston.
Im done with that. Just to much money to put that back together.
On the hunt for a clean iron block. Ill get it checked and hope its all good, I want to assemble a non-machine stock block. With my current parts.
Old Oct 23, 2015 | 12:23 PM
  #247
98TA6.0's Avatar
Heres a good use for it.
Old Oct 23, 2015 | 01:10 PM
  #248
I think its sellable as a fresh machined block... For someone that wants to spend money on it.
I totally was gonna make a table from a junk block, I already have a SBC in my living room tho lol
Old Oct 29, 2015 | 11:15 AM
  #249
Little update.
My buddy found an iron 5.3 that he looked at and said it was a solid block. But he still recommending a light line hone and ARP main stud. Main stud kit is $269 (ouch) but after all my past issues and im now essentially saving $800+ on not buying pistons, I went ahead and pulled trigger.
So had a nice Bill from Brian Tooley Racing for:
-New Melling oil pump- 10296
-New LS7 lifters
-New LS9 head gaskets- 12622033
-New MLS exhaust gaskets- 12617944
-ARP Main Stud Kit (234-5608)
I will have to wait to get block back I imagine at least a week, need studs before he can line hone. So I have everything I need to re-assemble this motor except main/rod bearings which I can't order until I have block back and check everything for sizes.
Old Oct 29, 2015 | 12:13 PM
  #250
67 goat's Avatar
Thanks.
Remind me again.....what were you asking for this truck when you were trying to sell it?
Thanks,
Jeff
Old Oct 29, 2015 | 01:39 PM
  #251
Thanks,
Jeff
12k. when it was running.
Old Oct 30, 2015 | 08:26 AM
  #252
98TA6.0's Avatar
Thats not that bad of a price. I got 9k for my stepside. But it had a completely restored interior and cold AC. It wasnt turbo of course.
Old Oct 30, 2015 | 08:45 AM
  #253
This truck is insanely straight/clean. All tough body work was all done and done right.
We'll see if this new meticulous motor build stays together, and maybe I can focus on aesthetics and other things I'd like to do.
Old Oct 30, 2015 | 10:44 AM
  #254
98TA6.0's Avatar
It looks very clean. Mine was decent and was a New Mexico truck so no rust. These old C10s are getting up in value.
Old Oct 30, 2015 | 10:49 AM
  #255
67 goat's Avatar
I assume you're committed to finishing the course you're on now? If not, how about a price for not running?
Old Dec 10, 2015 | 11:16 AM
  #256
Not much been going on lately. Waiting mostly.
Spend a little time smoothing out the transition on my oil pump. Id like to smooth all of interior but I don't have long enough mandrels for my dremel.
Finally got my block back yesterday. ARP mains installed and line honed, cam bearings installed, and cylinder hone, and clean. Block definitely needs some exterior attention, but im considering painting the entire assembly this go around (block w/heads,oilpan, timing cover all installed) That seems to look really nice when its all painted at same time.
I need to get some measurements and call to order bearings to get my clearances where I want. Guy that did my machine work mocked up stock main bearings and its factory spec with plastigage. I need to be looser with boost.
Old Dec 18, 2015 | 10:51 AM
  #257
Fairly typical fashion for me. Have hit a another roadblock, of course more money...
After receiving the block back, I finally got around to doing all the critical measurements to determine the correct Main/Rod bearings. To make a long story short, I invested almost an entire day to research to figure out that they don't make a rod bearing to suit my situation, which is a .002 overbore and .001 undersize...
So now I need to buy a new set of unmolested rods to install my ARP bolts and be able to use basically any bearing heart desires at that point.
So my Main set will be an ACL 5M7298HX which is .001 under to achieve the clearance goal I have in mind of .0023-25 range
Rod bearing will be same .001 under size ACL 8B663HX
Old Dec 28, 2015 | 09:35 AM
  #258
Well. Trying to get my crank setup perfect. Did 3 rounds of plastigauge. Still tighter than id like on 4/5. Snap gauges weren't getting a good enough measurement for me. So my Dad gonna come by with his ID mics tonight so hopefully I can get solid numbers to see if I can swap some bearing shells and get closer to my goal clearances.
These are some interesting looking bearings... Almost look pre-SPUN for me lol
Old Jan 7, 2016 | 08:33 AM
  #259
After numerous measurements with ID mics. All my Bore diameters are .003+
So I am ordering a std set and do half X half STD to tighten it up. So far 2 vendors I have attempted to order from have emailed me back after payment stating they weren't in stock and on backorder.
Finally Tick performance verified they had a set on hand and got me taken care of, so hopefully sometime next week I may FINALLY be able to get my crank installed.
Old Jan 7, 2016 | 10:27 PM
  #260
truckdoug's Avatar
i bet you're glad you mic'd it instead of just plastigage!
this ones a runner. I got a good feelin about it.
