1967 camaro ls swap
#46
#47
You can use the new Holley pan anywhere you can use a notched 4th-gen F-body pan as the sump length is roughly the same. Because of modifications to its width that were made, you don't have to suffer with the reduced oil capacity penalty that comes with running a notched 4th-gen pan.
Anyone who tackles this swap using the new Hooker/Holley components is going to be able to do so with far less head scratching than ever before and end up with a more highly engineered end-product than previously available.
With the engine bracket kit, two available transmission crossmembers and two trans adapter kits,you will be able to install the new Hooker headers on an LS engine backed with a 4L60-4L75, TH400, 2004R, TH350, 700R4, Powerglide, T56 or T56 Magnum transmission...choose your gear weapon of choice.
#49
For guys in the planning stages of their swaps, or guys struggling to install certain components or engine/trans combinations, this type of information can have a lot of value and end up saving them considerable money in the long run.
For guys such as yourself who may have your own way of doing things, I understand this information may have less value or seem like a gratuitous sales plug. If so, that's not my intention...I'm a design engineer here at Holley, not a salesperson.
I'm actually not an "okie" either as I'm a west coast transplant. I can however see the humor in the tag.
Happy Thanksgiving
#50
No problem.. I just felt like as I read the thread I was watching power block TV.... that is how to tension a Gilmer supercharger belt, now lets talk for 5 minutes about these great new shop towels...
Not upset with ya, just found it funny...
#51
I promise to sound as far removed from the "Sham-Wow" guy as possible in all future posts.
#52
c6matt nice build I really liking the super charger but if I had one I would probably die. I was on a test drive last year with a new ctsv sc and almost ate the curb with it when it hit boost. Was scary and fun at the same time.
#53
Question about ls3 pcv catch can? Could you use a vac canister for a catch can? I have a vac canister on core suport and was thinking I could put petcock on bottom and use like they do on ls3 catch can? Any thoughts?
#54
you could, but far from ideal, a good catch can has some baffles to force the oil/water out of suspension... Provent is the best out there IMO
#55
I get V's from work, my car makes them feel tame / slow..
#58
^^^I'm at this same point. Do you four link, or use drop leafs? I'm leaning towards the 4 link. By the time you pay $600 for the drop leafs, get good shocks $200, and use some kind of traction control $400. You can get a bolt in 4 link from Heidts for $1250 with free shipping with coil overs. I was all for the drop leafs until I started doing the math. Hope this helps.
#59
What size cam are you going with? I'm doing a swap right now in my 69, going with a 2004 lq9 block ls3 heads. I did buy the whole Holley/Hooker ls swap…can't tell you how it goes together yet. After pulling everything out i need to clean things up 1st and could take some time. Yours looks way more prettier
