LQ Fox Build
....the z k-members are junk......if u have the old LS z k-member your going to need to make new motor mounts so that u can move the motor back about 1-2 inches so the f-body oil pan clears the k-member.....and then the Dynatech headers will clear the steering shaft...
Even the 2nd redesign LS fox z k-members are junk.....guys have to cut the motor mounts off so they can lower the motor and move the motor forward or back....
Racecraft has nice stuff but they made the k-members so you have to use a Pinto style rack......by the time you buy all the parts needed you would be broke...
*GM swap 4130 K-member w/tow hook (3279GM) $574
*LS motor mounts (LSMM) $179
*Pinto rack w/billet rack clamp and hardware (333100-C) $288
*Bumpsteer Kit short length for pinto rack (333203) $119
*Pro Series Steering Shaft Kit (333143) $282
AJE LS k-member and AJE trans cross member for the win......the last 3 that i have installed has been excellent.....and Kooks,, Dynatech and Headmans headers will clear the steering shaft........not 100% sure about the Headman headers tho....
http://www.jegs.com/i/Hedman-Husler/...ductId=2167916
If you ordered the LS fox body z k-member and you use a th350 trans you might be ok ?? and the Dynatech Headers should clear the steering shaft.....
If your going to use a 4l60 or a t56 they won't fit unless you cut the motor mounts off so you can lower the motor....but if you lower the motor then the Dynatech Headers will not clear the steering shaft....
Finally got the motor bolted in for good, had to widen the passenger side mount holes just large enough to bang the bolt through. I also finally ordered a few small things dipstick tube,dipstick, and also a 160* thermostat.
My attention is now on the fuel system, I was dead set on just sumping the factory tank and running a magnafuel pump but I'm now debating going with a warlboro in the stock tank and a Bosch 044 inline? Really don't want a fuel cell in the trunk, and I'm seeing problems as far as locating the pump with the factory sumped tank. Any advice?
