MPG Machine
Rx7 swaps are the way to go! Look at norotors.com for ideas. The engine bays are huge in the 86-91 models.
When I had the 2.73's in my 86 RX7 with the 200-4R OD trans and L/U converter I would see over 30mpg highway at 70+ and click off mid 10 second 1/4 mile passes.
Had a mildly built 3.8 (buick grand national motor).
Very comfortable to drive. Sold it for $6500. Was roughly 2750lbs with out driver.
You should be kicked off this board immediately.
Put in an aluminum 4.8, t56 and 2.73 gears.
Wouldn't be surprised if you could pull mid-high 30s with that thing and still scoot pretty well due to the power/weight ratio.
There are some things within the engine, exhaust, drive train and PCM calibration that can help a good bit but in the end it's still a brick wall from an aerodynamic perspective.
OR, you could just get one of those hydrogen generator things that I have to hear about from my neighbor every time he comes over. His Jeep Liberty gets like 100 mpg or something. LOL!
While it does get 30mpg or so crusiing 70 in 6th, I still average 15mpg or so by the time you figure city driving in. If I baby it a week I can average 18mpg. Still not great IMO. Something lighter weight with a taller gear is the way to go.
also i think my clutch fan is on all the time. im really considering a swap to electric fans
IMO cheapest and easiest way on your current rig would be to buy cheap tires as narrow and tall as you can fit. Then run alot of tire pressure.
It's going to be tough to find a car that's lighter and is as easy to swap as the Miata. I'm running a 3.23 rear so it'll cruise at 80mph at 2K rpm. I've never kept my foot out of it long enough to get an accurate mpg, but I'd imagine it would be pretty good.
i had a 5.0 mustang years ago that had a clutch fan that went out. it was doing the same thing my burb seems to be doing, sounds like an airplane driving down the road. i picked up 3 mph at the track taking it off, thats basically 30hp
im sure your probably right though, probably wont make that much difference but i figured every little bit would help
1997 Thunderbird lowered 1.5 to 2" with 16" factory size wheels:
Gen III 5.3, electric fan, 4L60E with a junkyard transmission cooler, 3:23 gear with "411 style" custom tuned PCM using a 99 Corvette intake, LS6 valve springs and a Muscle Car oil pan kit. True 2.5" dual exhaust into 2.25" factory Thunderbird mufflers using some butchered and hacked (i.e. poor flowing) C5 corvette manifolds up front. Modified aftermarket custom air intake for a 99 Silverado.
I feel there is room for improvement if I build some good flowing short or mid length headers (nothing factory fits) and adjust the air intake to work as a "cold air" / ram air setup at speed. Right now the intake picks up some bleed through air from inside the engine compartment if stationary, however while moving the air temps stay within 3 - 5 degrees of ambient.
Full details on the car and budget are in my signature.
