Bruisr - 1968 Camaro
When I purchased this car it was exactly what I wanted. A running, driving, decently modified car! I wanted something I could buy and drive day 1 while picking up mods along the way to get it how I wanted it. So for this purchase, mission accomplished.
I quickly decided I wanted to go fuel injection with an LS swap so that's what everything will be based around. The use of this car will be street, autocross, and road courses (everything from HPDE's to time attacks). The only time it'll see the drag strip is when I go to just hang out with everyone else. Sure I'll probably do a few passes but nothing crazy, not setting the car up for that.
Car as it sits now:
- Eldelbrock TEC 200 Aluminum Heads
- COMP Cam 12-612-5 Solid Lifter Cam
- Roller Rockers
- Ceramic Coated Headers
- Holley Competition 750 cfm
- MSD Ignition
- Super T10 4 Speed Transmission
- Center Force Clutch
- 8.5 10 bolt posi 3.73 from 81 WS6
- Aluminum rear support cover
- Subframe connectors
- QA1 Adjustable Aluminum shocks
- 6pt Custom roll cage
- Hotchiks 2" drop leafs and Coilovers
- Hilwig 1 1/8" front sway bar
- Quick ratio 12.7:1 power steering box IROC HX box aka hot OEM setup
- All new suspension & body bushings
- Front & Rear LS1 Disc Brakes w/ Hawk pads
- BMW Parallel wheels 18x8.5/9.5
- Autometer Tach & Speedo
- OEM Forged Crank
- OEM polished rods
- TRW pistons w/ floated wrist pins
- Balanced rotating assembly
- ARP Head Bolts & Fasteners
- Scatter Shield
- Kenwood stereo and amp
- Redone interior
I took my wagon and drove 1.5hr to pick her up. 2005 with 64k miles
After speaking with an engine builder he's confirmed my thoughts of going aluminum. He knows my driving ability and even currently races with me in on the karting scene. He says I'll for sure notice the weight difference on the front of the car, welp that was short lived! Out with the LQ and in with an LS! I tossed up a FS/FT thread and came across someone who was looking for an iron block and currently has an aluminum LS6, woot! We are currently in the process of working out shipping but we're trading short blocks.
I plan to still use my 317 heads and toss some parts in them, not sure what yet. I'll want to go with a custom cam for boost and of course some springs as 7500rpm is desirable for me. It's current disassembled but I think that'll be fine as a stroker kit is in my future.
My LQ4 didn't come with an ECU or harness so keep that in mind. The LS6 is just a short block so no ECU/harness with it either. Below are the motor parts I’m leaning towards. After speaking with my engine builder and Texas-Speed it’s agreed that the 10:1 range is where we’ll want to be, going supercharger too. So this setup is trying to create this. I know Texas-Speed offers a stroker kit, just trying to list out part numbers here. The internals should be a 383 stroker setup, correct me if I'm wrong.
- Oil Pan – Holley Part # 302-2 (http://holley.com/302-2.asp)
- Callies Compstar 4.00” Crank – Part # 186-4.00Crank (http://www.texas-speed.com/p-480-cal...rankshaft.aspx)
- Callies Compstar 6.125” H-beam Rods – Part # 186-CsC6125DS2A2AH(http://www.texas-speed.com/p-421-cal...ting-rods.aspx)
- Wiesco -8cc 3.905 Forged Piston – Part # 10-K394F (http://www.texas-speed.com/p-1283-wi...iston-set.aspx) & Wiesco Rings
- Main & Rod Bearings – Not sure?
- Full ARP Studs/Bolds - Trying to find part #
- Head Gaskets - .040 thickness – Can’t find Part #
- Hooker Headers - Part # 2276-7HKR (http://www.holley.com/2276-7HKR.asp)
- Exhaust - No clue, custom maybe?
- Supercharger – Procharger, not sure which one yet.
- Head/parts – Undecided on specifics (7500rpm wanted) Current heads are 317's
- Cam – Custom grind not sure from whom yet
More parts for the swap and other upgrades:
- Engine Mounts – Holley Part #12618HKR (http://holley.com/12618HKR.asp)
- Transmission Crossmember – Part # 12626HKR (http://holley.com/12626HKR.asp)
- Transmission Mount – Prothane 7-1604 (http://www.summitracing.com/parts/ptp-7-1604-bl)
- DSE Narrowed Fuel Tank – Part # 080105 (http://detroitspeed.com/1967-1969-F-...uel-tanks.html **Email sent to Ricks to get info on a tank setup**)
- DSE Mini-Tubs – Part # 040401 (http://detroitspeed.com/1967-1969-F-...deep-tubs.html)
- DSE Quadralink Rear Suspension – Part # 041703D (http://detroitspeed.com/1967-1969-F-...UADRALink.html)
- DSE Axle/Upgrades - Undecided but need a new diff for sure
- Harness: PSI PN HAR-103 - http://secure.ultracart.com/catalog/.../HAR-1013.html
- ECU/PCM: PSI PN PCM-1003 - http://secure.ultracart.com/catalog/.../PCM-1003.html
- ECU/PCM Mount: PSI PN ACC-1030 - http://secure.ultracart.com/catalog/.../ACC-1030.html
- HP Tuners Pro: PSI PN 6021 - http://secure.ultracart.com/catalog/...NERS/6021.html
For parts where there are no Part #'s or I'm undecided again feel free to make suggestions. However, if you do please back it up with a reason and a link if possible!
An engine builder will do my machine work and assemble the short block and I'm no welder so mini-tubs will have to be done by someone else as well. I plan on doing most other things myself or with anyone willing to help.
Thankfully my wife is into cars as well and loves muscle cars. She actually pushed me to pick this car up, yesss!!! This isn't going to be a speedy build and will take some time to accumulate parts but hopefully I'll be able to keep a steady stream and get to know my UPS guy even better!
- Hooker Headers - Part # 2288-1HKR (https://www.holley.com/2288-1HKR.asp)
1. Mid-length headers available in both 1-3/4" and 1-7/8" primaries
2. Long-tube headers available in both 1-3/4" and 1-7/8" primaries
3. All the Hooker headers are installable with T56, T56 Magnum,TH350,
TH400, 2004R, 700R4, 4L60-4L75 or 4L80E/4L85 transmissions.
4. The Hooker 1st-gen exhaust systems are stainless steel and available in 2.5" or 3" versions and include all hangers and clamps. No cutting or welding is required to install the 3" system; the 2.5" system requires two cuts to install an adapter kit that mates it to the 3" collectors of the Hooker headers. They can both be purchased for under $800.
5. All the new Hooker 1st-gen components are compatible with the stock A/C evaporator case (even with the stock valve cover mounted coil brackets installed), SB and BB heater cores and the stock OE LS spark plug wires with the metal heat shields.
6. You can also install an automatic dipstick tube in-between the passenger side cylinder head and the firewall (1.5" nominal clearance)with the positioning provided by the Hooker engine mounting brackets and transmission crossmembers.
7. The Hooker components are designed with and maintain a 3 degree engine inclination angle and require no cutting to the floor to install.
Let me know if there's any other useful info I can provide you with.
[/QUOTE][IMG]
[/IMG]The Hooker collector ground clearance...
What size primaries do you guys offer for this application? Do you have exhaust system ground clearance and stock power steering box clearance photos?
Your build quality is nice.
