79 Pontiac Bonneville Buick 350 to LM7 swap.
So after my th350 started slipping and the Buick 350 made knocking noises. I decided that it was time to do this swap much sooner then expected. Anyways, I will say that going carbureted was the cheapest way to go. I wanted the car to look as original as possible. I will say finding info on ls swaps for B-body gm cars isn't easy, at least older pontiac b-bodies. One of the biggest problems I ran into was getting the motor mounts in the right place. There were about 3 sets of pre drilled holes but none of them worked out. But once that was sorted out, it was a breeze. For the motor mount bracket on the motor I made an adjustable plate so that I had some wiggle room. The exhaust manifolds I used were the cast iron headers by hooker. I'm sure camaro manifolds would had worked but I couldn't find a pair to save my life. I used the original Quadrajet on the LM7, which gives a mix of great power and fuel eco.
Nice. I love the B-Bodies. Especially the 2 door boxes.
Here's a link to swapping a Carb LS to a 87 Caprice. The mounting of the engine should apply to both EFI and Carb. As far as the engine mount on the K-member, you need to buy Chevy Caprice/Impala 77-90 with a SBC and the mount that attaches to the engine. This link helped my builder install my LQ9 in my 78 Impala coupe. He had never done a b-body LS swap before, but if I did the research, he agreed to do it. http://www.superchevy.com/how-to/eng...ped-ls-engine/
@1975delta88
I would have bought some mounts, but for the price and not knowing how things were gonna fit since i used the truck oil pan, i'd rather fabricating some. Either way, everything worked out fine.
That's awesome you were able to make what you have work. I was just providing a source of info for those who want to do a swap on B-Bodys from the other GM Divisions. In theory, this should info should also work for those who want to do this on a 77-84 C-Body (Buick Electra/Park Ave and Olds 98, and Cadillac Deville).
