Walbro 400 lph pump
Note, there are two versions: one for gasoline and one certified for 100% e-85 use.
http://www.nolimitmotorsport.com/pro...00267-400-0085
I think its same pump, just E85 version. I'm doing a turbonetics 76 on an L33 and really would like to run 1 intank. I have similar goals as mufflerguy. I have -8AN feed, -6 return and 60lb injectors.
Question really is will pumps shown above supply the volume single handedly that a 600-700hp engine will require?
The walbro will handle 700whp at 60 PSI, it will not at 85 PSI. Upping fuel pressure to increase injector flow ultimately reduced pump flow. You must find a balance to make them both work.
If I use the 96's, am I going to give up some driveabilty? This is first and foremost a street car. I'm thinking the 80's may be a better balance, but I'm not very educated on the finer turbo points yet. Is my thinking correct?
650whp can be made on a large single pump like the Walbro 400 on gasoline. 800whp on E85 is usually pushing the limits of a pair of the smaller Walbro 255s.
In these cases, larger injectors can usually take some of the stress off of the fuel pump(s). 96 lbs can still be ran with decent driveability especially if they are high impedance.
