fresh ls1 swap, shortly lived, ends in disaster
Just rubber lines? Does the Ls1 have the same high pressure pump design as the later model Ls engines?
My Ly6 is like 54 psi of pressure. A lot of the fuel line that I see for sale at most auto parts stores is not recommended for that pressure...
That's likely the factory fuel filter mount. My regulator is in the same spot in my 300zx. Heat hasn't been an issue, but I put heat wrap over the lines and my headers are wrapped as well.
Always carry a fire extinguisher, especially in something you built in a shed. Hopefully the car will return better than it was.
I have built 20+ cars on rubber hose, clamps and zip ties. Never a failure. The key is in the planning-and testing. Never mount a regulator off a rail with a brass fitting. Wrap any line that will see even mild heat. Use push lock fitting AND clamps (although a good push lock will never leak, and never come apart. I ALWAYS test the lines at max pressure and check for leaks any time I service the car. (take the regulator to full load. or clamp the line)
