5.3 not running good while driving
Thanks for your help
Thanks
You need 58 PSI at the rail all the time or the engine will not perform as desired. Don't be alarmed if it fluctuates a bit as the engine revs under load, it simply needs to stay within 3-5 PSI of 58.
http://www.novak-adapt.com/catalog/f...uel_module.htm
The regulator is located in the fuel rail. I am going to get e fuel pressure and test it.
I installed a fuel filter, one with 40 microns I believe, but I read somewhere the filters the trucks came with are not 40 microns. I will remove the filter and see if is dirty.
Thanks
My guess is you are hitting that far before you get to WOT. I would check static fuel pressure (pressurized with the engine off) and see how long it takes to bleed down, and running fuel pressure at idle. If it drives as bad as you say you probably won't have to drive the car to see it's low.
Things to look for off the top of my head are a pinched hose or fuel line, bad regulator, bad filter, bad strainer or poor pickup from the tank itself.
One thing to note: if you have a pressure AND return at the rail, the regulator is on the rail. If you ONLY have pressure, the regulator is elsewhere and the thing that looks like a regulator (pictured below and stolen from the Novak site listed above) is actually a pulse damper and never goes bad.
Last edited by gofastwclass; Mar 20, 2014 at 03:50 PM. Reason: Added pic stolen from Novak's site
The regulator is on the rails, it has a vacuum connection to it.
The fuel lines are braided from the rear to the rails, so the problem might be from the fuel filter to the fuel pump. Unless the pressure regulator is bad.
rpturbo, what do you mean, like having bank 1 o2, on bank 2??
fire67bird, is not a drive by wire..
Thanks for all your help
Your problem could still be a leaking injector, damaged line, regulator, filter or the pump and pickup itself.
I would check those things in the order I listed which is also the cheapest and easiest then make sure they are in working order. Sometimes the high pressure line between the in tank pump and fuel line will get pinched or compressed causing low fuel pressure. I've seen people use incorrect fuel line which isn't rated J30R10 (submersible) and it deteriorates in a short time.
Might try unhooking the vacuum line to the regulator and see what it does. With the line unhooked, it will max out your fuel pressure, so if you don't get at least 58psi, then either your pump isn't putting out enough pressure, you're losing pressure somewhere or something is restricted (pinched fuel line, clogged filter, ect).
5.3L Flex Fuel engine 2001-2004, 48-54 psi with vacuum line disconnected
5.3L Standard Fuel 1999 to 2003, 55 to 62 psi with vacuum line disconnected
No...I could be wrong, but I'll bet you have a bad pump...
I had a customer install one of those pumps, and it wouldn't keep up with his stock 5.3.
