sleeper build help
Old Mar 25, 2014 | 08:58 PM
stuck_on_stupid's Avatar
Default sleeper build help
hello, I have a 1968 Camaro with a lq4 going into it. im being told I need 3in exhaust with the power im having and I want it to be a sleeper. so im thinking go from my headers to a x pipe to cut outs to some sleeper mufflers. all 3 in. but I cant find any mufflers that are restrictive enough. the motor is going to have ls3 heads and intake and a tick performance cam. I hope ill have about 550-600 at the motor. just want something that is quiet so I can trick people. so any inputs on mufflers?
Old Mar 25, 2014 | 09:10 PM
BudRacing's Avatar
Headers to a Magnaflow X muffler, then two more magnaflows flanking the fuel cell if you can fit them. If not, some sort of bullet mufflers.
Old Mar 25, 2014 | 11:00 PM
does the magna flow x muffler does that work? @budracing
Old Mar 26, 2014 | 07:50 AM
lsxRanger94's Avatar
What about 3" x To cutouts then drop to 2.25 factory style mufflers back. Then you just open them up when you want to play. if you need it even quieter, mount a second gen transverse muffler between gas tank and diff.
Old Mar 26, 2014 | 08:22 AM
MX6.0's Avatar
+1, you're not gonna get much quieter or cheaper than a stock muffler.
Old Mar 26, 2014 | 09:48 AM
BudRacing's Avatar
Does it work? It's a high flow muffler. It's definitely not the quietest muffler, but it's mainly intended to be part of a series of mufflers as a resonator would from a modern factory setup.
Old Mar 26, 2014 | 10:33 AM
ok nice ill look into this and I have some flow masters that are not that loud I was thinking of putting those on? there on the car right now and with a 5.3 wot they wee still quiet
Old Mar 26, 2014 | 01:13 PM
or should I forget trying to make a sleeper and just put in a x pipe and straight pipe it after wards?
Old Mar 26, 2014 | 02:20 PM
BudRacing's Avatar
Haha, I would definitely not recommend straight pipes, especially after an X. From my experience, the X causes a good bit of turbulence and makes the note raspy. Sounds nasty at WOT, but during lighter acceleration it sounds bad.
If you're looking to have a "ripper" every once in a while, but be able to control volume when desired, then the cutout suggestions above would be the best method.
After thinking about it more, I think a setup like this would be better suited:
In addition, you could add slender resonators or bullets in the straight sections.
Old Mar 26, 2014 | 02:58 PM
could I just put some spintechs on then? I have a big cam so I don't think I should quiet it own. I think im just going to let it flow. I just want a cross pipe to even out the flow then some mufflers. my co worker has spintechs on a 408 build and it sounds nasty
