Stock oil pressure sender needed in LS swap?
Old 04-07-2014, 07:43 PM
Restricted User
JoeNova's Avatar
Default Stock oil pressure sender needed in LS swap?
So I pulled the old sender out and installed a T fitting for my gauges. When someone noticed it in a picture they told me I need to get one of the T fittings from ebay that have a hole in the top for the stock sending unit because it is needed for the ECU.
Is the stock sending unit really needed, and what does the ECU do with the oil pressure information? I thought it was just for the stock gauge and dash lights, which I don't have.
Old 04-07-2014, 07:58 PM
gofastwclass's Avatar
Gen III engines don't need the oil pressure sender, most wiring diagrams I've seen send it directly to a gauge or light in the dash. I think there are some Gen IV engines that send the oil pressure signal to the PCM. I say this because I believe I've seen it listed as an available PID to datalog and I thought I saw an SES code for it in one of the PCM's I was looking at.
I've always eliminated it and never had any ill effects.
The following users liked this post:
Homer_Simpson (01-07-2024)
Old 04-07-2014, 08:01 PM
mmarshall's Avatar
I did not use one. I plumbed an autometer sending unit into the port and ran the signal straight to the gage.
Old 04-07-2014, 09:22 PM
bczee's Avatar
Many of the earlier engine (Gen III) setups didn't use the oil pressure signal to the ECU/PCM but was in communication with the BCM and then on to the Dash Gauges.
This could be different for the VVT and DOD engines. What engine (year) and ECM are you using ?
BC
Old 04-07-2014, 10:31 PM
Restricted User
JoeNova's Avatar
06 5.3 L33. Its a gen 3.
Old 04-08-2014, 02:25 PM
geoff17's Avatar
+1 this is exactly what I did with mine.
Old 04-08-2014, 09:45 PM
Restricted User
JoeNova's Avatar
I'll try to look for a different T fitting then. I'm using the port for both oil pressure gauge and turbo oil feed and cannot find a T fitting anywhere. The only T fitting I've found is a 3" spacer that you screw the sender back into the top of, that has 2 holes drilled into the sides that are tapped for 1/8" NPT.
I might pick up one of these and drill into the side for a 1/8" NPT fitting: http://www.ebay.com/itm/Oil-Pressure-Sender-Adapter-LS1-LS2-LSx-16mm-x-1-8-NPT-/171278471172?pt=Motors_Car_Truck_Parts_Accessories&hash=item27e0fe1004&vxp=mtr
Old 04-08-2014, 11:36 PM
59belair's Avatar
You can just remove the top of the stock sender and drill/tap the remains for 1/8" pipe thread, then add a readily available T. easy to do.
Old 04-09-2014, 01:34 AM
Terry Smith's Avatar
Going off the 5.3, the factory sender is on the back top of the block drivers side. If you don't need the factor sender buy their adapter and put it right there. If you need the factory sender then don't buy their adapter and drill and tap for 1/8 pipe and the oil cooler cap off plug for your gauge sender.
Old 04-09-2014, 04:02 AM
ls1nova71's Avatar
On a 2006 gen3 engine you don't need the factory sender. Just break off the plastic portion of it and get down to just the aluminum part of it, then drill and tap it to fit whatever sender came with your gauges. Then for the turbo feed, drill and tap the block off plate above the oil filter. You could reverse the two if it makes it any easier.
Old 04-09-2014, 10:23 AM
69 Ghost's Avatar
Or just buy the equus adapter kit for about $10 from Az or summit....
http://www.equus.com/Product/9848
Old 04-09-2014, 05:03 PM
zamora7's Avatar
I bought my auto meter gauges from car shop Inc and they had everything I needed to make it work on my ls1. It uses an adapter and uses an older style oil pressure sending unit. If I can find a link I'll post it.
Old 04-09-2014, 05:12 PM
zamora7's Avatar
http://autometer.carshopinc.com/prod...s_id/8369/2268
This is what I used, world with their senders that come with the gauge.
Old 04-09-2014, 09:08 PM
Restricted User
JoeNova's Avatar
My problem is that the turbo is on the passenger side of the car so I need to use the factory sending unit location for the turbo oil feed. I was hoping to just tap into the side of this fitting for another 1/8" port for the oil pressure gauge.
Old 04-09-2014, 09:12 PM
cmac06's Avatar
I have one of the adapters that KUP used to sell to add up to three oil feeds and a sending unit. It didn't work with the FAST manifold. If you want it, shoot me a PM.
Quick Reply: Stock oil pressure sender needed in LS swap?
