LS1 Harness Question/FD Build
I'm currently going through a ls1 swap into my FD RX7. I recently purchased a ls1 from a 1999 Corvette. The motor came with the wiring harness and ecu but what I'm curious about is if the harness will hook up to a t56 properly. If I remember correctly the 1999 vettes came with a different transmission so that's the reason I'm unclear about if the harness will work with it or not. I was also told that I may have to go with a F body harness to work with the t56 but I'm worried that if I go that route I would have to change all the sensors out because they may not correct for whatever reason. Another question I have is will the f body harness hook up to the vette ecu or vise versa? All replys are greatly appreciated. Thanks for your time.
So if i dont want to keep the drive by wire and use a cable instead does that mean i have to get the f body harness? will the f body harness work with the vette ecu or will i need to get the f body ecu as well? And if i go with the f body harness will all i have to change the sensors as well? thanks for your help!
Thanks for the reply. Do you know if that harness will work will the t56 as well?
