New Hooker G-Body LS Swap System Preview
Old 02-05-2018, 05:45 PM
  #801
HighLiner's Avatar
Maybe but I know it’s not gonna fit like it is and I’m sure if I slide it forward the rest of the system won’t work.
Old 02-05-2018, 08:50 PM
  #802
user 4737373's Avatar
Are you having clearance issues with the A/C evaporator case, or something else?
Old 02-06-2018, 05:34 AM
  #803
HighLiner's Avatar
The HVAC system is deleted. I dropped the short block in and now in trying to put the passenger side head on, it contacts the firewall before it's even in position. I'd guess I'm 1/2-3/4" shy of making it.
Old 02-06-2018, 05:53 AM
  #804
Can you post some images of your mounts so I can confirm you were sent the right parts. There is definitely something askew for you to be having that problem.
Old 02-06-2018, 05:01 PM
  #805
HighLiner's Avatar
Don’t know what angle shows the best
Old 02-06-2018, 06:35 PM
  #806
So I know, what specific year/model of G-body are you working with?
Old 02-06-2018, 06:38 PM
  #807
Also, do you have your transmission installed, and with what crossmember?
Old 02-06-2018, 06:41 PM
  #808
HighLiner's Avatar
1979 Malibu w/TH350
Old 02-06-2018, 06:42 PM
  #809
HighLiner's Avatar
G-force crossmember but the trans is just sitting on it and not bolted solid.
Old 02-06-2018, 07:08 PM
  #810
Since I've never mocked-up a G-body installation using the G-force crossmember, I would suggest that you check your engine inclination angle relative to the bottom of the frame rail to get an idea as to where you're at with that characteristic. If the tailhousing of your transmission is sitting lower on the G-force crossmember then where it would be when using the Hooker G-body crossmember that will cause the cylinder heads to lean back into the firewall more.
Old 02-06-2018, 08:31 PM
  #811
HighLiner's Avatar
It's at the stock level.
Added later: I just went out and jacked the trans up until it touched the tunnel. I'm still half a bolt hole off from getting the head on.
Old 02-06-2018, 09:46 PM
  #812
What kind of condition are your body bushings in?
Old 02-07-2018, 08:22 AM
  #813
HighLiner's Avatar
Original to the car so I’ll give them a look over but I can’t foresee them sagging that much.
Old 02-07-2018, 08:50 AM
  #814
There's nothing off with your engine bracket/mount attachment as I can see in your photo that you have the passenger side mount lined up with the correct set of holes. Other than your engine/trans inclination angle being excessive, I can't see what the cause of your fitment issue would be. Here's a couple of reference shots of the engine in the Holley Monte Carlo SS that show the position of the back of the engine relative to the firewall.
The following users liked this post:
All Pontiac WS6 (12-02-2021)
Old 02-07-2018, 07:26 PM
  #815
HighLiner's Avatar
Looks super close on the Monte. Is there a reason you didn't move it a little bit forward.
Old 02-07-2018, 07:32 PM
  #816
Yes, moving forward any further would cause the alternator pulley on the F-body accessory drive set-up to experience interference with the steering box.
Old 02-12-2018, 09:58 PM
  #817
HighLiner's Avatar
Since Hooker doesn’t have a crossmember for the TH350, what angle would I be trying to achieve?
Old 02-14-2018, 06:25 PM
  #818
LS1 pwrd NOVA's Avatar
Good question... ^^^
Old 02-14-2018, 06:59 PM
  #819
onebadbowtie86's Avatar
as little angle as possible. I have a g force cross member in my car and I added a stack of washers between the mount and the cross member to get the transmission as high in the tunnel as possible.
Old 06-27-2018, 05:05 AM
  #820
GbodyJino's Avatar
Default Hooker Long tube headers With column shift linkage
I got this hooker set up. Everything is very nice. Thing that concerns me in the long tube headers fitting with the column shift linkage. I just set my gen 3 5.3 in last week. Next I'll be putting in my stage 2 4l60e. I have the hooker cross member. Now the shift linkages..
Quick Reply: New Hooker G-Body LS Swap System Preview
