LS2 with LS1 harness?
Old Aug 11, 2014 | 11:40 AM
Mercier's Avatar
Question LS2 with LS1 harness?
Hi,
Looking at buying a complete LS2 out of a TBSS. It comes with harness but no PCM. Have a complete LM7(early, return-style fuel setup if that even matters) with modified harness and PCM in the Jeep working just fine.
What am I up against getting the LS2 working with the LS1 harness and PCM?
So far, I see that I will need:
1x cam sensor retrofit harness
1x knock sensor adapter/extension harness
8x fuel injector harness adapters
Corvette-style fuel filter with integrated regulator or convert my old rails/regulator
90mm cable throttle body(already got this)
MAF?? Can I use my stock truck MAF somehow?
Is there any issue with the tooth count on the cam or crank?
If I stick with the LS1 harness, if the TBSS harness worth much?
Thanks!
Old Aug 11, 2014 | 12:45 PM
Pocket's Avatar
Biggest hurdle is the 24x LS1 PCM control (GEN III) vs 58x control LS2 (GEN IV)
Ligenfelter sells a conversion box, but there are mixed reviews of its longevity
Beyond that, just bolt all the externals from the LM7 on the LS2, extend the cam sensor connector from the rear china wall to the timing cover and get a knock sensor kit
Some early LS2s were oddballs using the GEN IV block and came stock with GEN III PCM control. These were all 24x engines, so conversions were quite simple because of the enormous aftermarket for GEN III vs GEN IV
Old Aug 11, 2014 | 01:07 PM
Mercier's Avatar
Ah. That will be the killer. Really don't want to open up the motor. Maybe just have to get a LS2 PCM and use the harness I get.
Any way externally to tell if a motor is the oddball(fingers crossed!) with 24x wheel?
Going to hopefully put my eyes on the engine this evening.
Thanks for the info!
Old Aug 11, 2014 | 01:23 PM
Pocket's Avatar
Black crank sensor is 24x, gray is 58x. If it looks to be tampered with, remove it and inspect the reluctor directly. Two saw blades side by side is 24x, one toothy sprocket is 58x
Old Aug 11, 2014 | 01:33 PM
Mercier's Avatar
So what about using the LS2 harness and finding a matching ECM? I want to stick with the cabled throttle body. How much trouble am I getting in that way? I do have HP Tuners and at least the ability to find where to turn things off that I don't need.
How much pain am I looking at down that road instead?
Thanks again for your help.
Old Aug 11, 2014 | 01:42 PM
Pocket's Avatar
The 58x system cannot be used with a cable TB. Not a single computer can control the IAC
The 24x system can go either way
Old Aug 11, 2014 | 01:48 PM
Mercier's Avatar
Well I guess that decides it. If I buy this I am out another $250 for the Lingenfelter converter box. Not what I wanted to hear but hey, that's the price of cubes and an aluminum block.
What is the complete LS2 harness worth assuming it is in good shape?
Thanks.
Old Aug 11, 2014 | 01:59 PM
Pocket's Avatar
Check ebay, they seem to bring more there than the penny pinchers on this forum
Old Aug 11, 2014 | 09:40 PM
Bowtiedford's Avatar
my 58x is cable
Old Aug 12, 2014 | 06:20 AM
oldgoat69's Avatar
What year is the LS2? Some of the earlier LS2's are 24 tooth. I used the E40 ECM and T42 for my LQ4. The ECM was out of a 2006 GTO. You must use the DBW pedal from the same family, but you can use a gold blade TB, which is 1/2 the money. I did the harness mods myself. I bought all of the parts from EFI Connection, very helpful and reasonable. And yes you can use the truck MAF.
Old Aug 12, 2014 | 11:19 AM
Mercier's Avatar
I hesitated and another buyer beat me to it. So the search continues.
It was later with 58x.
@Bowtiedford - please explain or detail your setup--this is not the info I have found but I am interested in the possibility if correct.
Thanks!
Old Aug 12, 2014 | 06:40 PM
I used the lingenfelter box, which converts it to 24x signal and a 12200411 PCM which is standard fare for a LS1 and I used a LS1 harness out of a 2000 Camaro. Along with all the adapters to the harness. I did go with the 5 wire mass air meter.
"1x cam sensor retrofit harness
Is there any issue with the tooth count on the cam or crank?" your quote
all of the above you stated I could have saved some money as the person who did my harness extended my harness for the O2's, extended the harness for the Map which is up front now and the camshaft position sensor which is on the timing cover, Knock sensors are on the side of the block, I used LS1 sensors and tapped the side of the block. Converted the MAF to the correct 5 wire plug since LS1's are 3 wire with the IAT on the tube somewhere. I already bought the inj adapters which he would have done anyway. Should have as him before I bought the stuff. Read and post and ask questions before spending money in the wrong direction. I wanted alum 6.0 and LS3 heads which I have now.
Oldgoat answered a few of my questions also.
Old Aug 13, 2014 | 01:04 PM
Pocket's Avatar
Originally Posted by Bowtiedford
my 58x is cable
With the converter box, it's 24x control. The point was no 58x ECM can support DBC
Old Aug 13, 2014 | 01:24 PM
Mercier's Avatar
Thanks for the clarification(s), guys.
I should be picking up a motor this weekend. It is a 2005 Vette LS2 so:
24X reluctor wheel on this motor right? So I should just need the wiring bits and be good to go with my LS1 harness/ECM?
Old Aug 13, 2014 | 04:11 PM
I said that because you said the 58x cannot use cable tb. But it can with the Lingenfelter box POINT gee
Old Aug 16, 2014 | 10:55 AM
SS69LS1's Avatar
I have an 05 LS2 vette ECM, pedal, and harness all off of the same 05 vette if you end up needing it.
Scott
Old Aug 17, 2014 | 11:18 AM
Mercier's Avatar
Thanks, Scott. I am hoping this will all connect up; the 2005 is kinda lucky for the LS1 harness guy(me) from what I can tell. Also already have the DBC setup worked out since the LM7/LS1 swap was working before, so I consider DBW as last resort for now. I will definitely keep you in mind though.
