Texas Speed
Old Aug 14, 2014 | 09:52 PM
Mike Blanco's Avatar
Default Texas Speed
I will be putting an LS motor into my restored 65 Chevelle. So I have been shopping around for engine builders in the Houston, TX area. If I do ultimately go with an individual shop to build my motor, I think I would like 500+ HP and am open to whether it be FI or not. I am not looking for anything exotic (at this point). It has been my initial impression that my cost is going to be anywhere in the neighborhood of 12K - 15k. Now that just includes the built motor.
After the motor is built I will still need the wiring harness, all the accessory drives, the install of course, and not sure what else I am missing here. So I have been continuing to poke around a bit and through this website and the numerous helpful people that have PM'ed me turned me on to Texas Speed.
It looks like to me they have engine packages with the whole 9 yards and all new components and parts even the block. For instance, I could get a new LS3 376 CI for just over 11K. It has everything on it all the accessory drives, wiring harness, pedal etc. Then to boot they have a 1 year warranty with unlimited miles.
So I know you always get what you pay for, and I am trying to figure out just that, is there something that I am missing here? What is the advantage of going to one of the custom builders when you have these kind of packages. I know it kind of has the big box store feel of the engine building world, but I am green and just wondering here.
Old Aug 14, 2014 | 10:20 PM
(SS)'s Avatar
My texas speed stroker motor is 12 years old and has around 35k miles on it if that helps you any.
Old Aug 14, 2014 | 11:09 PM
I will call these guys in the morning.
Old Aug 20, 2014 | 09:04 PM
(SS)'s Avatar
Update?
Old Aug 21, 2014 | 05:24 AM
HCI2000SS's Avatar
I'm curious too
Old Aug 21, 2014 | 07:35 AM
I called them a few days ago. Spoke to a salesman named Derek, pretty knowledgable guy and easy to speak to. I asked all the usual ignorant questions and he guided me along.
However, I just stumbled onto an lq4 w/ an 80E. All acces. Are there. Guy wants $1,200. I am going out there to look at it this morning. If it goes well I will be being that to my shop and stripping it down the. Try to figure out my next step.
Old Aug 24, 2014 | 08:46 AM
(SS)'s Avatar
Good find.My buddy has a 402 stroker with a th350 making over 500 to the ground.
Old Aug 24, 2014 | 10:37 PM
Thanks. We have the motor about stripped down now to the bare block. Still have to remove the trans, and the crank.
After a lot of thought I think my plan on my power plant is going to be 500 - 600 HP at the rear wheel. I think if I apply any more than that to this Chevelle we might start breaking some stuff. The recommendation from some of the engine builders has been to build the motors bottom end to hold 800 HP just in case I ever did want to go FI.
With that said what components do I need to start looking at for this lq4? Will I need to upgrade the crank? If I am going for 500 - 600 HP what heads should I be running?
Old Aug 29, 2014 | 11:29 PM
(SS)'s Avatar
Crank is good for 1,000 hp.Save the money and just have your cleaned up.
Old Aug 30, 2014 | 02:20 PM
I think I am pretty set on making it a 408. However, when I do the computations online for the displacement, I get the following information back. What am I missing to get to the 408 mark. Is it my cylinder ways will open up just a hair?
Number of Cylinders are = 8 to 1
Piston Diameter = 4.000 Inches
Piston Oversize = 0.000 Inches
Engine Stroke = 4.000 Inches
Computation Results:
Computed Engine Displacement (CID) is 402
Computed Engine Displacement (Litres) is 6.6
Computed Engine Displacement (CC) is 6589.7
Old Aug 30, 2014 | 03:02 PM
Kansas Bu Wagon's Avatar
Piston size should be 4.030.
Old Aug 30, 2014 | 07:47 PM
(SS)'s Avatar
lq4 aluminum block can go to 402ci
lq9 iron block can go to 408ci
I think that's how it goes.
Old Aug 31, 2014 | 11:15 AM
Lq4 and 9 are both iron. A 408 stroker is 4.030 bore and 4.00 stroke.
Old Sep 2, 2014 | 11:32 AM
roswald0511's Avatar
Why not get a junkyard engine and then build the bottom end later. It will be a lot cheaper that way. That way you get all the accessories with the engine. Sometimes you can even get the wiring harness. All for less than a grand.
Old Sep 2, 2014 | 02:29 PM
I already did get the junkyard lq4. I got all the accessories, just not too sure how good of shape the wiring harness is in.
