What fuel lines typically used?
Have yet to run the return line.
Just wondering if I should just plan on running rubber type return line, and how folks are accommodating the connections to the filter/regulator.
BTW...considering getting the LS1 kit at Tanks Inc.
I would use this kit:
http://www.purechoicemotorsports.com...rod/prd293.htm
The kit you listed uses Russell fittings which have caused major issues, like engine fires...there are several threads about them.
I would run as much hard line as you can and for the rest of the lines use Teflon lines braided stainless lines.
Andrew
http://www.purechoicemotorsports.com...rod/prd263.htm
Forty five degree double flares are easy to do and most car guys already have the flaring tool.
Andrew
C5 Corvette filter/regulator
Russell 644123 - qty 2 (use on regulator input from pump and input to fuel rail)
Russell 640940 - qty 1 (use on output of regulator to fuel rail)
Russell 644113 - qty 1 (use on return line from regulator to tank)
-6 (3/8) PTFE stainless braided lines with 37 degree JIC fittings swaged on the ends.
I brazed -6 steel AN fittings on the ends of my hard line on the intank pump assembly. Pressure tested to 150 psi with no leaks.
See post #56 for pictures.
https://ls1tech.com/forums/conversio...ers-etc-3.html
I think I have about $140 in the whole fuel system, not including the 255 intank pump, which I would have needed anyway regardless of which fuel lines I chose. Comparatively speaking, $140 is alot more than other people spent for an equivalent system, I just wanted the abrasion resistance of the stainless braid and I wanted the thread together EFI adapters which do not have the plastic clip that has been known to fail.
https://ls1tech.com/forums/4312143-post20.html
I also bought the Wix 33737 from
Russell Fuel Rail Fitting Adapters 640940 (3/8 in. to -6 AN)
Russell Push-On EFI Fittings 644113 (5/16 in. to -6 AN)
Russell Push-On EFI Fittings 644123 (3/8 in. to -6 AN)
With the CuNiFer lines you need to flare them to 37° and use a AN sleeve and nut.
