Holley AC compressor bracket spacer?
Old Aug 30, 2014 | 02:25 PM
454ragtop's Avatar
Default Holley AC compressor bracket spacer?
I'm using the Holley alt/PS brackets, with vette damper and water pump. Just picked up the Holley Sanden AC bracket, which unlike the alt/ps bracket, requires a spacer kit when used with the Vette components. Can somebody measure the thickness of their spacer? Don't feel like spending $50. for a chunk of aluminum and a bag of bolts when I can easily make that spacer. If anyone needs this bracket, I got it from Advanced Auto for $108. plus tax, with free shipping using discount code TRT30. Strangely Advanced doesn't show the spacer kit being available from them.
TIA, Jim
Old Aug 30, 2014 | 04:42 PM
KY Nova's Avatar
I'm thinking of trying that exact bracket on my setup to get better belt contact than I currently have with my current setup. When you get it on would you mind taking a pic and showing the front setup? Hopefully someone will get you the dimensions needed. Are they not on holleys' site?
Thanks
Allen
Old Aug 30, 2014 | 10:46 PM
dropped72ss's Avatar
I may have the holley ac spacer laying around. Lemme see if I can dig it up. If so are you willing to buy it?
Old Sep 1, 2014 | 01:09 PM
454ragtop's Avatar
Depending on cost, I'd definitely be interested in buying it, LMK. KY Nova, I didn't see that dimension anywhere on Holleys site. I have the engine on a stand, and will be happy to get some pics once it is all set up.
Jim
Old Sep 2, 2014 | 08:06 AM
1964SS's Avatar
I have one laying around for the F-Body spacing. I can give you it's dimensions and you can subtract the difference for the corvette spacing.
Old Sep 2, 2014 | 09:47 AM
454ragtop's Avatar
Cool, thank you, I should be able to work with that.
Jim
Old Sep 4, 2014 | 11:32 PM
1964SS's Avatar
My F-body spacer is 1 3/8" thick. And from what I read on the Holley site the corvette accessories are 3/4" shorter. You should be able to subtract the 3/4" from the 1 3/8" and have yourself a spacer.
Old Sep 5, 2014 | 04:50 PM
454ragtop's Avatar
1964SS, thank you very much! I'll mock it up with some 5/8" spacers and check the alignment, and then cut it out of some aluminum plate.
Jim
