ls in 1955
Old Sep 2, 2014 | 12:02 PM
lilrobo's Avatar
Default ls in 1955
i am putting a LS in my 55 , what are people doing about gauges? i know they need to be electronic , but the setup ,, if anyone has one post some pics please
thanks
Old Sep 2, 2014 | 12:51 PM
Adam123's Avatar
Look at www.speedhut.com Nice gauges, a bit high but able to customize. There is also dolphin gauges which are cheaper I think.
On par, I like the Speedhut the best
Old Sep 2, 2014 | 01:36 PM
Ach1992880's Avatar
direct fit ones from NewVintage look very acceptable.
http://www.newvintageusa.com/trifive.html
Old Sep 2, 2014 | 02:06 PM
garys 68's Avatar
You can run any gauges you want. The only one that needs to be electronic is the tach. The speedo can be mechanical if you're running a trans with a mechanical output.
I'm running all stock gauges on my 68 vette. Mechanical speedo, converted electric tach, mechanical oil pressure, electric original temp (just use the original sender)
Old Sep 2, 2014 | 08:43 PM
dlove's Avatar
Check out our new LS gauge controller and see if it fits your needs.
https://ls1tech.com/forums/new-produ...ontroller.html
Old Sep 3, 2014 | 05:29 AM
Pop N Wood's Avatar
+1
Pretty easy to adapt the sensors off the old motor to the new one. Lots of threads on how to do so. Analog speedo can be a bit more of a hassle depending upon the trans. Many aftermarket transmissions have both electronic and mechanical outputs. A couple of companies make modified tailhousings that convert a modern trans to mechanical output. You can also buy a cable box that drives a mechanical speedo from the VSS output. They are pricey and seems like lots of people complain about problems.
Keep in mind if you upgrade to new gauges you often need to find a new way to include things like high beam indicators, turn signal, etc. Never worked on a 55 so don't know if that is an issue.
Old Sep 3, 2014 | 08:08 PM
6.0 1955's Avatar
What body harness are you running? I have an autowire setup specific to tri-fives made it easy for either new electric guages or stock style gauges. My 6.0 is utilizing mechanical gauges by using speed and performance adapters to fit sending units. Good luck and enjoy!
Old Sep 3, 2014 | 08:27 PM
1970camaroRS's Avatar
I'm running a GPS speedo and a quad (temp/volt/oil/fuel) Speedhut, both 3-3/8". Absolutly love them.
Old Sep 4, 2014 | 03:00 PM
rockytopper's Avatar
I was looking at building a custom one for my 55 nomad using an original. But it would still require mounting the other smaller gauges in a console. So I’m leaning towards the Dakota digital in a black face with white letters to mimic the original. http://www.dakotadigital.com/index.c...rod/prd719.htm
This is the one I mocked up using autometer gauges.
Old Sep 4, 2014 | 07:19 PM
Speedhut is exactly what you need. Get a pair of their quad gauges and and speedo with the tach in it and you're set.
You can make a million different combos with all of the color options. Oh, and you can make them light-up whatever color you want at night.
Old Sep 5, 2014 | 09:29 AM
Thanks but only 3-3/8 gauges will fit in the 55 bezel. I already mocked up classic instruments version of the speed hut gauges with all in 2 and I felt it just doesn't flow with the dash itself. And having to use 3-3/8 makes it very hard to read the gauges. I'm not getting any younger lol. That is the main reason I'm considering the DD VS setup.
Rocky
Old Sep 5, 2014 | 11:16 AM
Ach1992880's Avatar
While I personally prefer the look of the NVU gauge that i posted above, I can't disagree with the other guys about speedhut gauges. I have a set of my own for my 71 Cutlass and I'm impressed with their product.
Old Sep 5, 2014 | 12:21 PM
Wow your right that is a nice gauge from NVU!! I don't care for red needles but overall a very original look. I had seen these before from another supplier but they only offered white back grounds. This one is very nice and on the top of my list now.
Thanks
Rocky
Old Sep 5, 2014 | 05:25 PM
oldgoat69's Avatar
Depending on which generation ECU you are using Speedhut offers the can-bus series. These take the signal off the ALDL and make a really clean install.
Old Sep 18, 2014 | 08:10 AM
lilrobo's Avatar
Got the gauges done i went with auto meter , now i am working on exhaust, , need to figure that out now
Thanks
Old Sep 18, 2014 | 06:58 PM
lilrobo's Avatar
i went this
now i am on exhaust i need mufflers of some sort
Old Sep 18, 2014 | 07:32 PM
garys 68's Avatar
that turned out very nice
Old Sep 19, 2014 | 05:58 PM
SUPERBOOST's Avatar
Originally Posted by lilrobo
i went this
what gauges are these?
Old Sep 23, 2014 | 02:56 PM
lilrobo's Avatar
Auto meter
