running wires under the intake?
Old Sep 10, 2014 | 09:35 AM
bluezq8's Avatar
Default running wires under the intake?
Has anyone done this with success? I like the idea of hiding the wires as much as possible, and since I am building the harness, it wouldn't be a big deal.
I am just wondering if it is a good or bad idea. Any thoughts?
Old Sep 10, 2014 | 10:24 AM
lsxRanger94's Avatar
Gm has done it with success. Knock sensor wires are under the intake on gen iii. How many other wires will fit under there and how big of bundle is hard to determine without trial and error. If you cut down the reinforcement ribs, I bet it would work for most of the wires. Just servicing the harness would be PIA. Or you could be lazy and get a set of Corvette fuel rail covers. LOL
Old Sep 10, 2014 | 10:40 AM
bluezq8's Avatar
I have thought about covers, but space is tight and I have always thought covers were a lazy way to clean stuff up. haha I will pull the intake off today to see what kind of clearance I have to work with.
Old Sep 10, 2014 | 11:24 AM
bczee's Avatar
As long as you don'f bundle the wires, you well be ok. Try grouping them like a ribbon cable and lay them flat.
Old Sep 10, 2014 | 11:46 AM
-TheBandit-'s Avatar
There is enough room between the intake cover and intake to run wires. The temperatures should be lower in this area than under the manifold. I gave this a try and it seemed to work okay, but I ultimately decided not to do it because R&R of the intake would be a pain. Here is a photo:
Instead I decided to run them on the top next to the fuel rails. This isn't quite as hidden, but I can easily remove and reinstall the harness when needed. Here is a photo:
Old Sep 10, 2014 | 11:53 AM
That would have been cool. If you could have turned the injectors to the inside even better.
Old Sep 10, 2014 | 12:51 PM
bluezq8's Avatar
I like that idea alot! But I have an LS6 intake with no cover.
BTW Bandit, I read your entire build thread and your attention to detail on the wiring has inspired me to put that kind of detail into my harness!
Old Sep 10, 2014 | 01:23 PM
Here's an idea. Don't know if it would work though. I think the flat space between runner by injectors is solid enough. Could you drill through there and fish wires up?
Old Sep 10, 2014 | 01:28 PM
bluezq8's Avatar
That may be an option. I am ok running the injector wires up top because I need to run the coil wires there anyway. I was thinking of running stuff like MAF/TPS/Alt/etc. under the intake.
Old Sep 10, 2014 | 01:33 PM
If you can do the holes between the runners, Just unpin the connectors and fish through. Then put a weather pack connector at back of intake so you can remove intake and wiring in one shot.
Old Sep 10, 2014 | 01:42 PM
JohnnyFbomb's Avatar
Bandit, that looks fantastic!
Old Sep 10, 2014 | 04:55 PM
fieroguru's Avatar
I used the fuel rail to hide the majority of my injector harness by turning the injector connectors around:
Old Sep 10, 2014 | 05:20 PM
@ FieroGuru You should post that coil bracket you built too. I think you could hide the bracket with coils down low like the old v6 used to.
Old Sep 10, 2014 | 05:31 PM
33willys's Avatar
Default Wire loom
How many wires need to be extended past the intake? Not going to run some under the intake and then double back I'm sure.
Old Sep 10, 2014 | 06:34 PM
Jimbo1367's Avatar
Clint,
Never thought of doing it that way. Great idea.
I plained on running some under my intake and want to run the injecter wires were the recess in on the head. I bought some heat barrier tubing like the knock sensors use a few years ago.
Old Sep 10, 2014 | 08:53 PM
fieroguru's Avatar
The coil brackets were just some 1/8" steel, some 1/4" x 1 spacers and some 1/4" carriage bolts from Lowes. I looked at putting them down low, but I like where they are as it has a little of the SBC feel with the plug wires wrapping the side of the valve covers. My primary goal with them was to hide all the wiring and connectors going to the coils. I am OK seeing plug wires.
Old Sep 11, 2014 | 06:43 AM
bluezq8's Avatar
Also a super clean swap Fieroguru!! I like the idea of turning the injectors around.
Old Sep 11, 2014 | 06:49 AM
Even if that bracket was used up top say the valve cover, it would look a lot cleaner than the GM bracket. Maybe the s10 guys or my swap could of used them to keep from hitting heater box.
Old Sep 11, 2014 | 11:01 AM
Below is another hidden wire example where the wires are just carefully hidden under the fuel rails. More info in this thread: https://ls1tech.com/forums/conversio...g-my-ls44.html
Old Sep 11, 2014 | 11:52 AM
Briou's Avatar
Just get a kinsler and you can run everything under it with plenty of room to spare....
But on a real note I would try the flat ribbon style technique...
