SN-95 LSX swap build thread
Old Nov 12, 2014 | 12:03 PM
redline2k's Avatar
Originally Posted by 64post
Removing the glass and cutting the top off is the the preferred method for a lot of builders but, it seems like a lot of extra work when the main hoop can be dropped through the floor pan (through some 2" holes) before it's welded in to access welds on top. It looks like it's coming along well. Are you mixing 1.750" and 1.625" to build that cage?
You can't get the bars as close to the roof with it on the car. Plus all the cuts are hidden by plastic panels on these cars. I already had the glass out because the car needs body work and paint. The down bars to the torque box and subframes are smaller tubes than the main cage.
Old Nov 12, 2014 | 12:06 PM
redline2k's Avatar
Got the LS3 gmpp heads today
GMPP LS3 ported head
Exhaust ports
Old Nov 22, 2014 | 01:32 PM
redline2k's Avatar
Cage, dash, and steering column all ready for paint
Old Nov 30, 2014 | 11:02 AM
quick85vet's Avatar
This car is gonna be killer. Great job!!!
Old Nov 30, 2014 | 11:52 AM
redline2k's Avatar
Thanks, we got the cage painted and are ready to weld the roof back on. I also sold the 94 racestars and have a set of 92's on the way. Going to try to shoe horn a M/T 29.5x10.5 in the back.
Old Nov 30, 2014 | 12:38 PM
roswald0511's Avatar
What are you using to fasten the dash?
Old Nov 30, 2014 | 10:56 PM
redline2k's Avatar
Has 2 dzus fasteners on top by the down bars. I will try to get you a picture tomorrow.
Old Dec 1, 2014 | 08:35 AM
redline2k's Avatar
Scott Rod Cowl Filler
Dash Fastner
Old Dec 1, 2014 | 05:09 PM
BSmiff's Avatar
Looking good bro.
Old Dec 2, 2014 | 01:19 AM
Blown06's Avatar
8 Second Truck Club
Whats the trick to cutting the top off and then getting it back on? Properly?
Old Dec 2, 2014 | 06:19 AM
redline2k's Avatar
Just have to be patient and line everything back up. On sn95 all the cuts are covered by plastic panels inside and out. So when done no one will know it was removed.
Old Dec 2, 2014 | 02:38 PM
  #32
redline2k's Avatar
Got new rims and tires today. Going to have to get rear centered in car now.
Passenger Side on and it fits
Racestar 92 15x3.75
M/T 29x10.50R15
Old Dec 2, 2014 | 04:02 PM
  #33
jgh64pkup's Avatar
Im running the same front runners on mine. They seem to hold the road good. Im not near as fast as your gonna be though.
Old Dec 5, 2014 | 04:30 PM
  #34
redline2k's Avatar
Old Dec 5, 2014 | 08:00 PM
  #35
quick85vet's Avatar
This car is coming together nicely!!! Keep the pics coming!!
Old Dec 8, 2014 | 04:00 PM
  #36
redline2k's Avatar
Scott Rod Firewall panels
Firewall filled
Old Dec 26, 2014 | 08:18 AM
  #37
redline2k's Avatar
Factory Shifter Hole Delete
Aerospace Manual Brake Conversion
Brake Pedal
Making Clearance for 7.25" Backspaced Rims
Sheetmetal Work in Wheel Well
Team Z Lower Brace
UPR Anti Roll Bar
ARC 12 Switch Panel
Switch Panel Mounted to Cage
Relay Board
Trunk Floor Removed
Interior View
Old Dec 27, 2014 | 03:26 PM
  #38
Tim94gt's Avatar
Awesome Build!
Wish I still had my Sn95. Great platform to start with. Looking forward to updates!
Old Dec 27, 2014 | 09:44 PM
  #39
redline2k's Avatar
Originally Posted by Tim94gt
Awesome Build!
Thanks!
We started to line up the front fenders and mount the hood yesterday.
Old Dec 28, 2014 | 03:59 PM
  #40
pantera408's Avatar
Going to be a Beast....
