small question about springs and retainers
Old Nov 6, 2014 | 08:41 PM
b body professor's Avatar
Default small question about springs and retainers
Hello ,
i have this question i didn't find any good answer about it so any help will be appreciated
so i bought this ls6 cam with springs and push rods, problem is the gay didn't send me the retainers and keepers , so can i use the ls1's ??
thanks gays ..
Old Nov 6, 2014 | 11:39 PM
TipsyMcStagger's Avatar
Originally Posted by b body professor
...problem is the gay didn't send me the retainers and keepers...
...thanks gays ..
Not that there's anything wrong with that
Old Nov 7, 2014 | 08:51 AM
ls1nova71's Avatar
Lol!!! I would think you could use your stock retainers though.
Old Nov 7, 2014 | 11:21 AM
Lol so you think ls1's retainers and keepers would do jest fine ?
thank you for passing by
Old Nov 7, 2014 | 01:17 PM
Nissan LS240's Avatar
With an ls6 cam don't think you'll be spinning the motor to 7k so youll be ok, if you plan on turning some rpm's I would consider lightening up the valve train with some better keepers and retainers
Old Nov 10, 2014 | 08:17 AM
yup , i will be fine jest with 6.200 or 6.300 ,
thanks bro
Old Nov 11, 2014 | 09:05 AM
KCS's Avatar
KCS
Moderator
The LS1 retainers and locks will work just fine.
Old Nov 12, 2014 | 06:43 AM
bczee's Avatar
I have replaced my stock LS1 springs and cam with LS6 springs using the stock LS1 keepers and retainers. Suggest you check for push rod length if using a stock LS6 cam. I ended up using 7.425 (stock LS1 is 7.40).
No problems.
BC
Old Nov 12, 2014 | 07:00 AM
LilSlo1's Avatar
Hello ,
thanks gays ..
Kinda off subject, but you should probably reset your autocorrect. Apparently, you must text "gay" alot.
Old Nov 12, 2014 | 07:54 AM
ooh ****!! , my bad
so sorry guys
Old Nov 12, 2014 | 09:21 AM
ooh ****!! , my bad
so sorry guys
It's obvious to me now that my Seinfeld reference from five days ago sailed well over the top of the OP's head
Tipsy
Old Nov 12, 2014 | 10:51 AM
No problems.
BC
i've bought the ls6 push rods with the cam , i will be using them with the ls7 lifters and ls1 stock rockers but i will be checking the length i guess
thanks alot
