Header problem...
Old Dec 18, 2014 | 07:40 PM
S10xGN's Avatar
Default Header problem...
Hi All,
I've been looking for headers for my Rambler swap and finally pulled the trigger on some 2010+ Camaro 1 3/4" longtubes (Pacesetter) because all I had to go by is eye-balling pix. No header maker ever includes measurements! The DR side fits fine but the PASS side outer tube is in the frame rail and upper CA. The thing is, with the bolts loose and a 1/8" gap at the top of the flange, it all clears. So, I have some options:
  • send them back and keep looking.
  • cut the flanges off and weld new ones on at the proper angle.
  • angle-mill the flanges.
  • find some angle-shim material and use two gaskets.
The headers are coated, so I'd prefer not to cut/weld the flanges. I took them by my favorite machine shop, the guy took one look and said there's no way to fixture them for milling. Got another machinist bud looking into this. If I have to cut/weld, is there some kinda spray that can come close to matching the coating? I'd hate to have them stripped and recoated.
Anyone know if there's any kind of "shim" available to kick the tubes in towards the pan rails? It would need to be 2 5/8" x 18" with 0" at one edge and 1/8" at the other...
Attached Thumbnails Header problem...-100_3345s.jpg   Header problem...-100_3346s.jpg   Header problem...-100_3347s.jpg
Old Dec 19, 2014 | 07:00 AM
user 4737373's Avatar
Originally Posted by S10xGN
Hi All,
Russ, does Pacesetter offer a painted version of the same header? If so, that would be your best choice from a cost-saving perspective since you can modify the geometry as-needed and then send them out to be coated.
Since your geometry seems so close you may want to contact Pacesetter and see if they will sell you a matching port flange to replace the one on your headers now. I would start with a painted set of headers, cut off the old flange and sink the header into the new flange on the car and get everything lined up as needed before tacking the assembly together. You can then take it off the car and weld it up.
Header manufacturers don't normally publish header measurements due to the fact that most headers are designed to be application-specific and are not intended to be installed on any other vehicle other than the one(s) it's listed to fit in the manufacturers application guide. They actually discourage attempts to do so to avoid customers such as yourself having a negative experience with their product.
Old Dec 19, 2014 | 08:07 PM
S10xGN's Avatar
These were $328 shipped, there were some painted ones for $268 but it would cost almost as much to send these back as the saved value then another $250 for coating. I've done the flange swap before on my Maverick, using LS flanges on Ford 351 headers and that venture (with coating) was over $750. I may try and hand grind these flanges to the angle I need, worst case is a new set of flanges...
Can coated headers be welded w/o stripping the coating? Is there a "paint" that mimics the color of the coating to cover the welds?
Old Dec 19, 2014 | 08:22 PM
You have to sand back the coating with an abrasive disc to expose the HAZ area before you can weld it (stinks real bad when you sand it too), but the tubes will weld fine once you do. I've never seen a paint that is a perfect appearance match or that has the same resistance to heat that the coating does, so the repair is going to become obvious in a short period of time.
Old Dec 19, 2014 | 10:12 PM
LLLosingit's Avatar
Any chance you can mount the header on a fixture or table and put to heat in it and bend it to get the clearance you need. From the pictures it doesn't look like it needs much to clear and looks like you have room at the collector to not cause problems.
If you heat it evenly you should be able to put a slight bend in it without any kinks.
Old Dec 20, 2014 | 07:59 AM
jozw30's Avatar
I was in a similar boat as you. After having tried six different sets of headers for my 55 olds 88 (used to live 15 minutes form Summit), I had a set that fit great on the left side but would just hit the frame at the collector flange on the right side.
Decided that it would just be easier to pie-cut the collector to turn the flange parallel to the frame and be done with it.
Found out that you can dissolve the ceramic coating with the gel type Drano. Was skeptical, but it works great. Don't need to grind it off. There is a primer left that light hand sanding takes care of.
Going to be an expensive set of headers in the end but the only ones left to try were in the $700+ range anyway.......
Good luck.
Joe
Old Dec 20, 2014 | 12:56 PM
Fry_'s Avatar
If it's not to late I'd return them and buy some stainless steel ones from Speed Engineering. Then you can cut and weld them all you want without worrying about them rusting and they're cheaper also at only $280.
http://www.speedengineeringlsx.com/2...inless-25-1017
Old Dec 20, 2014 | 06:55 PM
compton-z28's Avatar
i would make some sort of jig to bolt it down to,heat them up and try to bend it a bit like someone said earlier
Old Dec 20, 2014 | 09:29 PM
S10xGN's Avatar
Is that for real? I've seen SS 1 7/8" LT's in the $800 to $1000 range! Don't know what it takes to weld SS, all I have is ER70s mig wire...
So, where do you run the heat to bend four tubes at once w/o kinking them or destroying the coating? I'm thinking this is above my pay grade. If I could afford enough low-melt Cerro metal to fill the tubes, I wouldn't need heat - just brute force...
Old Dec 20, 2014 | 10:22 PM
Fry_'s Avatar
That would work except the welds would rust. It would be best to buy a small spool of 308L wire and rent a bottle of tri-mix He/Ar/CO2 gas or if you can't get that 98% Ar/ 2% CO2 will also work. It would weld fine with regular 75/25 gas but that high of a CO2 content would add too much carbon to the weld reducing it's corrosion resistance allowing it to eventually rust.
Either that or just pay someone to TIG weld them for you.
Old Jan 6, 2015 | 07:34 PM
S10xGN's Avatar
Figured I'd check back in with results. My first attempt was to use a carbide burr to remove about 3/4 of the welds (which were all on the inside of the pipes), cut the (fab) tacks on the outside tubes, then use a hydraulic pull cylinder to "winch" it over. After leaving the ram pulled in for three days, then relaxing it, no change. Guess the welds went deeper than they looked.
Finally did what I should have done from the start, used a Sawzall to slice the tubes from the flange. This would have prevented me from scratching up the coating on the flanges cutting the spot welds. Used the burr to finish removing the tube stubs. After doing this, I could also "slant" the tubes by cutting 1/2" from #2, 5/16" from #4, 3/16" from #6 and angling #8. That allowed the collector to move away the trans a bit.
The tubes fit tight enough not to need tacks, just marked tubes #2 & #8 with a marker pen to see if they moved while removing the header. Threw some tacks on the insides, then test-fitted. After removing again, I welded each tube from the inside running about 3/8" weld at a time and immediately quenching with a soaked towel. This keeps the coating from getting trashed. There are a few spots where it bubbled a bit, but mostly on the flanges where the mass was heavier. Once in the car, the flanges are hard to see. I'm gonna run them as-is and if they start spalling, I'll send the one header off for a recoat. Ended up with 3/8" on the frame rail and 3/4" on the starter case...
Attached Thumbnails Header problem...-100_3406s.jpg   Header problem...-100_3407s.jpg   Header problem...-100_3412s.jpg   Header problem...-100_3414s.jpg   Header problem...-100_3416s.jpg
