86 Stepside C10 LQ4 build
I would love to bag this thing. The way it is, I've actually got this one dropped 3" front, 5" back...I get anywhere from 14 loaded, to up to 18 empty, in perfect conditions. I am very impressed with the extra power and mileage compared to the old 7.4L SM465 combo.
My mileage almost doubled...I went from 8-12 mpg to the above mentioned with only a stock LQ4 6.0 4l80e combo...
This build of yours is very cool, I don't mean to hi-jack, just always check back on this thread. and saw your post about a dually...
Can't wait to see it at the tracks and the results.
This is how much needs to come off the inside of each rail for it to fit.
My battery box, due to pure luck, fit inside two holes that were already in the frame. Still trying to figure out how I want to mount it to the frame. Thinking about just welding it. The battery should only weigh about 11lbs.
I wanted to get a feel for the finished width so, I rested the slicks against the frame and chocked them. I think it looks kick ***.
6"x 3-1/2"x 6" I cut, bent and welded the bracket when I still worked on the race team. Dimpled die'd it right after I moved back home.
I guess I didn't get it in the pictures but I ran a piece of square tubing from above the dash to right about the top of the door striker. There is also one from the piece of square tubing down to just below the dash.
also, looking back through your pics i saw you trying to fit that mustang tank. i think you could cut the rails down that much and do something to stiffen them back up, either a horizontal rib skip welded on the inside of the rail, or maybe a fishplate on the outside of the rail. especially if you have a big crossmember in there behind the tank to stiffen up where the leaf hangers attach to.
