fox body guys! ignition solenoid? other wiring connections...
so for that ignition/power block I would just like to delete the other thing and delete the ugly wad of wires there in the drivers wall. so my question is do I just connect the starter signal wire coming off the gm starter to that rubber boot wire coming through the firewall and just put the yellow, black, hot starter wire, and alternator wires all on the positive post of the battery? any help would be great. thanks...
these are the main wires im working with minus the battery and starter cables.
this is the solenoid that sits in the bay on the drivers side. its for the stock 2.3 but I believe it is unnecessary after switching to the gm starter and motor. (not mine)
this is a diagram of the three post design even though mine Is a 4 post design with the only difference being there is an additional small post that runs to the smaller post on the starter
looks like everything on the red battery cable post is needs to stay to pick up power. battery cable can go directly to battery post on starter. the wire that pushes on should go to crank starter on S terminal. I would hook all wires that hook on with red cable now I would put on back battery stud on altenator. Run a heavy wire to either battery or starter battery post to carry charging current to system.
and judging from the rest of what you said I can run a wire from the battery post on the starter to the battery post on the alternator that will have the yellow and black/white stripe wires to run the 12v accessories in the cabin and run a cable from the alternator post to the battery post correct?
so what your saying is to hook the "S" (small starter post wire) and "I" (the push on red with blue stripe wire) wires together and that should trigger the solenoid on the starter so that the motor can fire up correct?
