LS3conversion- what front springs to use?
I am doing and LS3 4L65 conversion on a '67 Lemans convertible. Since the LS3 weighs a lot less than the 326 I need to know what front spring to use on it to get the right height back to what it was. Car does not have AC. Does anyone have an experience with this and can help me? Thank you.
I swapped mine for a set of QA1 adjustable coil overs on the front of my 64 so I could precisely set my ride height. If your on a budget and it's sitting a bit too high I would just cut half a coil off and check the height.
I think I can use 6 cylinder springs because the motor weight's seem to be about equal, but there are multiple different springs, which ones would I use? Thanks for the help. This just a daily driver, not trying to make it a race car or raised up too high. Just needs to be as close to stock as it be. Thanks
